Bird Engineering Minibike
gocartkid
Bad Attitude
CT
Well I acquired this from a friend of a friend (what a classic story, right?). I bought this and a brand new kart frame (see my thread in the kart section) with parts for a total of $200. Not bad, since the bike is complete and has a new clutch on it. This was bought as a kit from Bird Engineering out of Nebraska. The previous owner welded it up (NICE welds) and through a B&S flathead on it. It's either a 2 or 3 horse, the numbers are below a thick coat of paint on the shroud, so I'm gonna have to take the paint off to find out what it is. It's got no spark as of right now. Easy fix though. It has ok compression. I plan on restoring this bike to mint shape, but I don't know if I want to rebuild this engine for it or go with others that I have. I have a few choices (all of which will be built before installed): Briggs 2/3, Briggs 5, Tecumseh 6 (OLD engine, would be period correct for the 70's mini bike era), and a 2 stroke Tecumseh 3. Your input would be appreciated here. Well enough rambling on, here are the pics:
Kenny_McCormic
Kartless....
Michigan Troll
Either the 2 stroke or the briggs 5 with racing parts (you can build one for next to nothing, you can get a 6000 rpm safe raptor rod, stiffer valve springs(get some that float at 6k so you cant over rev), and a used cam for under $75)
gocartkid
Bad Attitude
CT
Oh, and I have a question for you guys. The brake is a rear scrub brake as you can see in the pics. I don't like that style at all and I don't want to keep replacing worn out rear tires (like what's on it now). So, what are my options here? What will work? I'm a noob in the mini bike world so any help would be apreciated.
sayre315
Rupp enduro
Oklahoma
yea, you could get a:
raptor rod
dyno cam
milled head
raptor crank
and some fancy valve springs
for around $100
oscaryu1
Raptor rod = $20 shipped
Used Dyno Cam = $30 shipped
Milled head = $30?
Raptor crank = unnecessary
And two exhaust valve springs will do. CompGoParts
Kenny_McCormic
Kartless....
Michigan Troll
You dont want a milled head, kills flow, unless milled means its been welded on top and the valve pockets have been milled to make it look like a heart shaped deal.
Shave the eyebrows and clean up the ports while your in there.
jr dragster T
Cold place
That link with the mini drag bikes are using blockzilla's. A built blockzilla will cost around 2800 bucks at the cheapest. There is one guy on youtube that has a 3 1/4 bore engine in his bike. Just the 3 1/4 bore engine will cost you around @4500-$5000 online.
jr dragster T
Cold place
And about the raptor crank. Oscar is right it is 100% not neceary. Some people at my track are running STOCK briggs cranks and running 8.30's.
Roy Vanas
demon since birth
for an easy brake, try a $7.00 oil filter wrench as a band brake around the centerfugal clutch....CHEAP CHEAP
gocartkid
Bad Attitude
CT
Yea, I know they are. They were just representations of what I am going for on this build. I have a few stock 5 horse blocks that will be sent out to be bored. Hopefully they will all clean up, one has severe scoring. I will be building it based off of Oscar's guide in the engine section. Anyone have suggestions for a cam? I've been looking at a few, but I was wondering what your experiances are. :thumbsup:
gocartkid
Bad Attitude
CT
Ok, thanks for the input. I almost bought a milled head but shyed away for that reason (it was milled a LOT). I'll clean up the casting in the head.
