please help asap
Nissinator1996
i finally got my 5 hp B&S running and on my go kart. it runs without a clutch(comet 30 series) and revs just fine...when i put the clutch(comet 30 series-Belt driven) it still runs but wont rev or go any faster when i have it floored its almost like its just idling the whole time...please help
Nissinator1996
all of the parts rotate freely, it is the right sized belt its the same belt it came with it was running and driving perfectly....p.s. i just went out there to try an start it again and now it wont start and it the exhust pops really loud but no start
Nissinator1996
the keyway is fine as it is brand new just put it in before i ran it yesterday..could it be from the weights in the clutch as i only have 1 spring on it and its really messed up plus i dont have the brass bushing to go one the clutch for it to ride on...it still pops when i try to start it now but it doesnt start.
klicky96
Sandusky, Ohio
take the TC Driver off of the engine. Then inspect the engine itself. Check and make sure your exhaust is on tightly. Make sure your carb is on tightly. I would't run that TC without the bushing and second spring.
jamyers
Buffalo Gap, TX
Yup, best to solve one issue at a time.
r97
Measure twice cut once
Massachusetts, USA
You didn't have the CVT on the engine and it worked fine correct? Then you installed the CVT and you ran into problems right? Did you removed the CVT and tested the engine again after that?
I too think it is a broken key problem. My theory is that you installed the new key but didn't torque the flywheel nut correctly. Then you tested the engine, which you had found to be working well. Finally when you installed the CVT and tightened the crankshaft bolt you accidentally dislodged the flywheel key, or possibly bent it. This threw off the timing causing the engine to not rev far past idle. This problem was possibly made more severe when you started the engine multiple times, moving the key more and throwing off the timing even further. This would cause the engine to make the popping sound and not fire.
Does that sound like a possible scenario to you? I also agree that you should get the CVT in a functional state before testing it to prevent further damage.
I concur. If you installed a new key, I can't help but think you did not properly torque the flywheel nut and sheared the new key. It would cause your no-start symptoms. Check it, assume nothing. Also- looking at pics, it appears something is largely out of whack.
EDIT- Also read through the thread entitled, "Maintaining your Torque Converer"
