7/8 pully clutch options
sexyvicta
I'm looking for a clutch with a 7/8 bore. idealy it will have a pully on it but thats not that important as i could chop a sproket off a normal clutch and weld on a pully. Does anybody know if there is enough meat in the 3/4 bore maxtorque to bore it out to 7/8?
What is available in 7/8 bore? over here can only get the maxtorque in 5/8 and 3/4 with a sproket on it. Or can get realy expensive($300+) custom idustrial clutches and racing kart clutches which are also expensive.
to replace the engine pully on this so i can ride it without starting on a hill or having a friend push start me:
thanks
sexyvicta
ah did a seach and see this has been covered before. Sorry. Looks like i will start by seeing if the 3/4 maxtorque will work. A 1 inch clutch with a sleave would also work but they cost more
r97
Measure twice cut once
Massachusetts, USA
Any chance you could get the crankshaft into a lathe? Or is that more work/money than your looking for?
sexyvicta
yeh thats my plan b. Know a guy with a lathe, its just a bit of a mission to pull down/reassemble the engine due to it having hard to get gaskets and 4 million uncaged needle rollers on the bigend lol
sideways
Unfinished projects king.
Perth, Western Australia
I have seen 7/8th clutches on American eBay before, maybe check that out and email a few guys on there?
Alternatively, quite a few wood chippers have a v belt on a centrifugal clutch with a 1" bore. It wouldn't be to hard to get one of those and hunt down a 1" OD pipe with a 1/8" wall thickness and make a shim with it. That's what I would do anyway. :D
Edit. Anderkart brings the goods! :D
sexyvicta
Maybe you can find one in OZ, the Comet Part# is 202313A.
Im in NZ and nah i don't think so. Only clutches that are that cheap over here are maxtorque and reel mower ****. Which are all 5/8 or 3/4. Heaps of 1 inch stuff but its expensive. Lawnmowershop said they'd never seen anything with a 7/8 clutch fitted.
Jcotz
...wasn't there
NY
Did you get your engine used? Because I thought I had a 7/8 shaft, but it turns out the extra 1/8 of an inch separating it from 3/4 was actually part of the clutch that I got with the engine just stuck on. I realized this after I bought a new engine :ack2:. You may want to check that though.
sexyvicta
yeh nah its 7/8 or could be 22mm or something if its one of the italian tecumsehs as 7/8 stuff seems ever so slighty loose(probably normal clearance), when you slide onto shaft...Iduno i didn't measure it with verniers only a ruler. Currently running a 7/8 taper lock bush thing with a 67mm pully on it
