CustomShifter
Man that sucks... but how thick should my frame be
like thickness of the wall.
It depends what style frame you're going for and how much you want to spend CDS/Seamless tubing as per rollcages is a stronger tube/weight. For tarmac I'd aiming for around the 30mm / 11/4" if it was to be a similar design to normal tarmac karts.
Jordan
Make sure you keep us updated.. looking forward to seeing a vid of this soon.In summary though.....my rear engine mount has taken a step backwards. The freedom of both rose joints means that the engine sways about 20mm side to side, which is what I was afraid it might do. I'm going to have to limit the sway somehow, but I might make something else altogether.
Quote:
How about 2 more long turnbuckes attached through that top motor mount bolt, and angled all the way out to the side frame rails. I remember you were concerned about chain clearance, but it kinda looks like that side might clear when bolted to the engine up higher like that.
