clutch??
CrazyFazy
Hi guys newbie here to the carting world. OK i am trying to get my sons cart running right but am running into some problems. The cart is a 5.5 HP honda engine with a centrifugal clutch. The original carb on the cart would run better if the choke was kept half closed leading me to believe there was a fuel restriction somewhere so i removed the carb and tried to clean it but the jets would not come out. After purchasing a new one i installed it and it kind of still does the same thing. Fuel restriction to the carb isnt an issue. It seems like there is a heck of a bog when you hit the gas even with the new carb. Another problem is that when my son sits on it and mashes the throttle it wont hardly move at all.Tore the clutch apart and cleaned it and still doesnt work. If i raise the rear tires off the ground or put the front end against something it will spin the tires but any weight on it at all will almost stop it completely. Could the centrifugal clutch be history? I havent counted the number of teeth yet on the sprockets but i will do so tomorrow as its 10 degrees here without the wind chill...lol. The guy who owned the cart before me raced it and was also wondering if the gearing was designed for speed instead of torque? The axle sprocket looks real big so wiouldnt that give me the torque to at least pull out? Thanks for any help anyone can provide on this.
klicky96
Sandusky, Ohio
The problem could be that the clutch is burnt out since the rear sprocket is pretty big. If the rear sprocket was small, I would say that it wasn't getting enough torque. I recommend buying a heavy duty clutch because it will last longer.
No- A large rear sprocket does not cook clutches. In fact, the opposite is true. A larger rear sprocket lends to an overall lower ratio, making life easier for the clutch. A rear sprocket that is too small overloads and cooks the clutch.
While it is possible that the clutch is bad, you need to examine the gearing before proceeding. Determine WHY the clutch is bad, if it indeed is. Leaving things overgeared will only cook the new clutch.
Re: the carb- even a new carb requires tuning. Read the spark plug to diagnose fueling issues.
CrazyFazy
ok i will post the tire size and the 2 sprocket sizes tomorrow. Anything else you need to determine the proper gearing? Thanks,,,eric
It wouldn't hurt to know what kind of kart is is, estimated weight with driver, and intended terrain/driving style. Am I correct in thinking it's a race kart?
CrazyFazy
ok the plug is kind of black which tells me its running rich but doesnt this seem strange as its runs better with the choke partially closed? With the choke partially closed you are actually giving less air to the carb for the amount of fuel being used? Wouldnt the plug be showing more of a white look to it than black?
CrazyFazy
its not really a race kart just your ordinary kids go cart. As far as terrain it just has the small tires so i would be happy if it woud just take off and run up the street. My boy goes 100 pounds and it wount even pull him up over a little curb....
klicky96
Sandusky, Ohio
After reading what i wrote, it seems that it is misunderstood. I meant, since the rear sprocket is big, then the clutch may be burnt out, not because the sprocket is big, but because the clutch could just be worn down.
The bigger the rear sprocket, the less chance of the clutch being burned out or worn down. It engages properly with a lower gear ratio, therefor less wear and tear on the clutch
jamyers
Buffalo Gap, TX
True, but, it could still be burnt out, clutches don't last forever.
True, but it's easy enough to tell - if the engine lugs down under load the clutch is engaging. If not, it's slipping / worn out.
But first you need to make sure the engine is running properly. Bogging under load could be a number of things - weak ignition, wrong air/fuel mix... I'd start with ENSURING a strong spark and a good clean sparkplug, then look at the carb.
klicky96
Sandusky, Ohio
Yes, i didn't read all of the other comments, i was trying to support my point. But if they engine is bogging down, it's probably not the clutch.
Jake.B
California-USA
Fuel air mixture maybe? if its getting to much air and not enouugh fuel shouldent you adjust the screw to give a little more fuel and a little leess air? Correct me if im wrong more experienced people.
CrazyFazy
bottom sprocket is 45 and the top is 10. When ya hit the gas it stumbles alot however if i could just run it by the governor it works great. The clutch is definitely slipping. The motor runs better at a little higher rpm so is there a way i can get a clutch that wont kick in so soon? That way i could have the engine rpm's a little higher so it runs better.
South Kart3377
Kart designer
Va
Holy cow, thats a small rear sprocket when landuse said big he is talking 80-100 tooth not 45. with a 45 I am suprised it can move itself with out the driver. BOTTOM LINE: You need at least a 60 tooth I personally would go with 80 or more if you are not using a TC.
jamyers
Buffalo Gap, TX
Yeah, holy cow 4.5 to 1 is tall gearing! Unless you've got really tiny tires, like 6-8 inch, that's going to be a dog to get going from a stop. Most karts seem to have at least 6 to 1, 8 to 1 is pretty common.
CrazyFazy
tires are 13 x 5.00 x 6 so what tooth sprocket would you recommend now? And yes it doesnt even move with my 100 pound son on it. The guy who owned it before me use to race it so i guess thats why the taller gearing. Thanks for the help guys.
CrazyFazy
oh and another thing is that i am only 7/8 of an inch away from hitting a crossbar that connects the frame together so not sure how big i can go with the sprocket....
CrazyFazy
hmm..........so am i to assume then that my centrifugal clutch might not be bad after all....lol No wonder it would go like hell up in the airbut not at all on the ground. How do i know what kind to get? I dont know if the bolt patterns are even the same...lol
jamyers
Buffalo Gap, TX
With little room for a bigger driven sprocket, you may have to use a jackshaft to get a lower overall gear ratio.
I suggest checking out the formulas for using/finding RPM, MPH, Tire Size, and Gearing in this thread. http://www.diygokarts.com/vb/showthread.php?t=9591
I plugged them into an excel spreadsheet so I can play with the variables.
Jackshafts are available at several places on the web, if you've got a NorthernTools near you they sell them as well.
