i completely forgot to mention but it's really important to go with DOM tubing and not just ERW, as ERW can and will split at the seams.
Oh sweet Jesus! Not the seam thing. DOM does not have a physical seam after production. It starts life as cold rolled welded seam tubing and is cold worked after welding by drawing it over a mandrel to remove the weld flashing and further work harden the tube. Sometimes you can still see the seam, but it should not compromise the concentricity of the tubing. Hrew or Erw is fine. DOM is overkill for this application. I have been building rockcrawlers for years and have yet to have a piece of hrew split. I know it has happened but triangulation and design are major factors in preventing this. DOM is far better as far as psi and strength but you are talking 3 times the cost of hrew. With Hrew always bend with the seam on the inside of the die. Most splits occur at the bender not on the trail. This is due to placing the seam on the outside face of the die and that is the part that stretches the most.
with AutoMX. I used the manual one to do all the work on my kart.
