My Kart Project -
RyanSGriffith
This is my first kart.
I started with a Honda Fourtrax 200sx fourwheeler that had bad bearings, breaks, twisted frame, etc.
It still ran great and was probably fixable but parts were becoming harder to find. I started to pull the thing apart and took the engine/5speed trans out to build a kart.
Initially I planned to make my own frame but found it hard to start not knowing what parts I would need or no basic layout.
I found a 60's Clarke or Rupp (Still undetermined) race frame that was mostly complete. Only needed pedals, break cable, throttle cable and an engine.
I am working on fitting the engine and running lines
As it appeared the day I got it.
The floor was not original and the weld job was terrible so I cut it out and replaced it with expanded metal.
I also started cleaning up the wheels and steering wheel.
RyanSGriffith
Yes I will be using the quad engine.
That is what the engine came out of.
Here is a video of one (not mine):
http://www.youtube.com/watch?v=Hj3b3TUM1Pg
As an atv, I remember having it up to 47mph. I will be using the same sprockets and chain off the quad. Being that the tires are much smaller on the kart and it weighs less, I am guessing the speed will be slower but acceleration will be much faster
RyanSGriffith
Ditched the quad engine because it wouldn't fit. Went with a hf 212cc.
12t clutch, 72teeth on the axel.
Got it all in tonight. Pics tomorrow
hes using 35 pitch chain so he cant have a 10 tooth clutch and his gearing is perfect IMO. Its not that heavy of a kart!
Aaaah. I didn't notice the pitch mentioned. I had the same problem with my minibike. I wanted to go from a 14 to a 10T, but the pitch didn't allow me. I had to buy a 12T sprocket, and when I had a keyway cut I had to get the machinist to press a collar over it because the keyway nearly went all the way through the sprocket.
Here is a pic of it.
