Does anyone know if there is some sort of sprocket that can reverse the direction another sprocket is turning?
The way I am fitting my engine is with the shaft on the right side instead of the left side. This basically moves the cart in reverse if hooked up normally.
My worst case solution involves idler sprockets that will change the direction of the chain to go past the bottom of the axle sprocket to reverse the direction.
This picture illustrates what I am referring to.
The ideal solution would be some sort of sprocket that has a opposite rotating sprocket attached to it. I am not sure if something like that exists.
Please keep in mind my axle will not have a 10 tooth sprocket. It's just for illustration purposes.
Let me know your thoughts guys.
