durostar engine
I am no expert, but I would go for the duromax or durostar, just because they are advertised as gokart engines. The predator is a all purpose engine. The predator, if I am not mistaken, is also only 6.5HP. I could be wrong with that though
You should be fine with any of them though
MrGrim
Louisiana
i know color has nothing to do with it but i love the color of the dourstar but anyways yes the predator are 6.5 hp. but iv never herd of durostar for gokarts i thought they were for genorators
MrGrim
Louisiana
O yeah I wonder I'm gonna call them today and ask what's different between durostar and duromax
r97
Measure twice cut once
Massachusetts, USA
All are likely to be exactly the same internally (china), only differences between the 3 are cosmetic.
Badot
Not to mention the gas tank is wedged into his armpit whilst he maintains a fairly natural arm position :roflol:
5h4de5_O-O
the duromax was only $126 out the door at overstock.com i just bought one myself:]
r97
Massachusetts, USA
http://engines.honda.com/models/series/gx
http://www.robinamerica.com/series.aspx?sid=7
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=robin+subaru&_sacat=See-All-Categories
http://www.northerntool.com/shop/tools/category_engines+honda-horizontal+121cc-240cc-honda-horizontal-engines
Any of those, or an old Techumseh, Kholer, or Briggs and Stratton(will likely need a bit of work at first). Only downfall with Subaru (and I mean the only) is less bolt on mods available, although there are still enough to modify them to the degree most anyone on this forum would (You could just keep it stock!).
If your really interested search the forum for "lawn boy duraforce" you will find lots of information on lawn boy's 2 stroke engines. You could also look for Muchollen (IDK how to spell that) Note that this s NOT at all a bolt on option.
sexyvicta
Why? And what would you go with any why?
i think as a north american you should support your local industry. Insted buying from a chain store which employs people at minimum wage to sell throw away engines, made in china by workers earning next to nothing.
lol
r_chez_08
Should be in the shop...
Cornwall, UK
im thinking of buying a durostar 7hp engine for my gokart but idk witch is better the durostar , duromax or predator. im starting the tread because my other ones getting no love :toetap05:
http://www.generatorfactoryoutlet.com/gfo/nav/accessories/Gas-Powered-Engines.asp
As said before, they are all clones.
If you must get a clone, then I would get a clone with the same bore and stroke as a honda gx200, 68x54mm IIRC.
This is because spare parts and performance parts are more readily available.
I personally would choose a yellow clone from NR RACING.
This is because they are said to be of a more consistant quality.
However as also said previously, there are also many other reasonably priced alternatives to the chondas, such as 4 stroke briggs, techumsehs, hondas, subarus, anything else with a horizontal shaft of 5/8", 3/4" or 1" and hp between 2 and 20 can be easily used on a kart (2 or 4 stroke).
There are also many alternatives, vertical motors and motors with different shafts that can be used on a kart with modification.
You can also use motorbike engines for high powered shifter karts or buggies.
Sorry for repeating stuff lol, i'm bored!
