Torque Converter best gear ratio?
bgm94
How should i gear my reverse trike with a TAV2 torque converter (10 tooth drive sprocket).
Specs:
11hp
16in tire
About 30lb bare frame
Which rear sprocket should i buy for a good top speed of around 50mph but still having good acceleration?
Thanks!
You're feeding a TAV2 11hp? What's the shaft size?
You can hit 50MPH by gearing to 3.4:1 THEORETICALLY. Geared that high, you may not have enough power to hit top speed at all.
50mph might be aiming a bit high. Bare frame weight means squat. Loaded weight including all running gear, a full tank of gas, and the driver is what counts.
What's "good" acceleration?
bgm94
Thank you for a quick reply Toystory
Some sort of acceleration where one can do burnouts and get pulled back into the kart seat, but i have a question, does adding a torque converter increase top speed or just torque?
Either, or, or both depending on gearing. Adding a CVT is like adding gears. Gear low, you get more torque. Gear high, you get more speed. Find the right ratio, you gain a bit of both. Bear in mind that even a CVT only adds so much, it doesn't perform miracles. If you're looking for a tire-fryer, gear maybe 6:1 or lower and forget about that 50MPH. Still need more vehicle info to narrow it down.
bgm94
hmm. well with engine, rider, and complete kart im assuming about 300lbs total.
Then you'd better think about upgrading to a Comet 40 or equivalent- I think you're gonna be chewing belts up like nobody's business unless you gear quite low.
I don't think 50 is in your near future. Here's why- my previous setup
310lbs combined weight
17.5" (measured) rear tires
Honda GX340 11hp, fundamentally stock
Comet 40 CVT
4.8:1 gearing
46MPH@4200RPM
Acceleration was nothing to write home about. I was considering gearing lower, but then opted for new drivetrain.
B man
Tecumseh FTW!
Oliver springs,Tn
11hp should be fine with a tav2. geared reasonable ofcourse. the engine turns 3600rpm normally. and dosent create all that much more torque then say a 8hp counter part.
