How To run a engine on Methonal and Ethonal?
Justin9;180329 said:
more timing... a methanol engine will run on gas, but it will spit and spudder and you will have to keep the throttle open some or it will die.
"More" timing? Do you mean further advanced or retarded?
crazyman
Yorkville Il
Alot of the tractor pullers (kohler) that use methanol have an explosion strap to keep the cylinder head on in the event of catastrophe. Methanol is pretty stout stuff. Be careful.
slideways
Your project would be much better if you compared the fuel consumption of 2 or 3 different (same) engines running the 3 different fuels at the same throttle load for a period of time. You won't be able to get one engine to run correctly on all 3 fuels as was said above.
In order to run meth you'll need about 1.5 times larger the jet size on both main AND pilot jets. You'll also need to advance the timing about half of the width of the keyway (get a stock key and shave it down).
Then you can run one engine on 1/2 gallon of meth... and 1/2 gallon of either gas/eth blend and see which runs longer.
Hint: Methanol burns about 1.5 times more fuel than gas does. But it provides more power and is safer in racing conditions.
