Auto Darkening welding helmets
fowler
Bullsbrook West Aus
intresting to point out
my mask will not react to the sun
it works fine with welds and is a name brand mask
but the sun gets no result
Simon Thomas
Sarawak, Malaysia
Correction
I might be wrong with the sunlight test to check on the response time. May be not a reliable test. I am not really sure too. That day after exposed the mask to sunlight, I lifted the mask and check the response time. The mask responded to the sunlight and turned dark. That is the thing I did. Some more my mask is not a branded unit, nothing much could be said. Apologize for earlier statement if this is not technically correct to test auto darkening mask's response time.
However, I recall correctly before the shop sold it to me, he tested it with the cigarette lighter (with the spark) to show me the response time. The spark from lighter turned the mask screen darker. It is a simple test. I believe this is more accurate.
pat.m23
Chester, ME
i have had my helmet for four years now and its a hobart hood i have not even changed the batteries yet and it is the slor type. if you r looking for a helmet go with one that is 1/24000 sec darking speed because the 1/12000 sec can still damage your eye. Miller makes good helments too. I like my helmet but its an arc sensing not an electrical sensing so when you get in tight placing the sensors dont darken. My next helmet will be a speedglas 9100xx.
jman231994
Australia
I doubt anyone has said this yet, but, dont grind in an auto darkening welding helmet. I grind in wearing my flip up helmet all the time just for a bit more protection than safety glasses and it seems to be fine....stupidly went to do it wearing an auto darkening helmet one time.....start grinding...bam no vision. Also it might wreck the lenses....I dunno lol
Just my tiny bit of quite stupid input
DustinWolfe
Meridian, Idaho
i disagree. im a steel fabricator and wear a speedglas hood. i grind in it all the time. alot of hoods have a "grinding mode"
jman231994
Australia
I'll have a look for it if i'm ever using the auto darkening one. I really only know about the on button and the tint settings. haha. thanks for the info I'll try to have a look
For those of us that DO NOT have one with a "grinding mode"- many times in the past I popped the auto shade out of my Lincoln or ESAB mask, and just left the clear lens in place for full-protection, close proximity grinding. Since the clear outer lens is replaceable and cheap, I found it to be a good and quick solution. Note- some masks allow you to do this very quickly and without any tools, yours may or may not.
DustinWolfe
Meridian, Idaho
you misunderstood me. i dont have grind mode. thats my point. i use it for grinding all the time. in fact this is me at work building a jig.
edit: i thought about it and it could be potentially dangerous so i guess your mileage may vary
will1384
About month or two ago Harbor Freight had a sale and I got the
"Auto Darkening Welding Helmet with Blue Flame Design"
Item # 91214
And used when making a stand for a bandsaw, I was shocked
that it worked so good.
BTW this unit does not recharge the batteries, once the batteries
are dead, you ether disassemble the unit and replace the batteries
or buy a new welding helmet.
Here is a page on how to replace the batteries
Harbor Freight Auto-Darkening Solar Welding Helmet Repair
