machinist@large
Yup it burns like someone shot napalm in your eyes, burns like h3ll with your eyes open, burns like h3ll when your eyes are closed.
Did I mention painful ?
Has anyone mentioned that you have a flare for understatement?
Haha, funny, that almost exactly how Id describe the beach-sand-in-eyes-wash-it-out-with-salt-water sensation. Alot of people starting out get lazy with the helmet and end up with burned retinas. Most people never have it happen again.
?I am quite new to welding and never attended any professional welding course. Most of my welding works that I do now, just learned from friends and relatives. Some from youtube and asking here and there. I ever used the conventional type of welding mask and recently purchased an auto darkening welding helmet. To save some money, I just purchased the China made a unit around RM200 (probably USD60-70). So far so good. I only weld with 60-90 Amps with small rod and never had flashing problem with it. Only weld occasionally depending on the need.
I just wonder how to check whether my auto darkening welding helmet with / without the battery powered:toetap05:? During the purchase, the shop owner just demonstrated with the cigarrete lighter spark and it turns the screen to darken. As simple as that! The box keeping my auto darkening welding helmet does not have the specification as well. My unit has two knobs inside the helmet for (i) filtration and (ii) sensitivity.
Without opening the casing, hope those that know the answer can advise whether my welding helmet is with / without the battery powered?
Some helmets appear to have a non-replaceable, rechargeable battery. They use the photoelectric eye to trigger, but run on some sort of capacitance.
A few years ago when I was welding as part of my job, I had two identical Lincoln-branded auto's. One was a backup and rarely got used. Every now and then I'd have to leave my main mask at a job and go to another and whip out my backup. OUCH!!!
It didn't take too long to figure it out. After sitting in a dark storage cabinet for months at a stretch, the mask would lose it's charge. I'd put it on, hit the trigger (FCAW), and promptly blind myself. After doing this a couple of times I learned that if I had to use my backup mask, I would leave it for 5-10 minutes directly in front of a lightbulb to charge before using. You see, normally, they'd charge themselves just from the welding process, but months in storage would leave the unit drained.
.what brand and model number? easiest way is to check the manufacturers website for spec or the instruction manual.
