Identify My Engine
kendelrk
redneck engineer
westland michigan
i beleive in an application for a motor for a go kart/mini bike its 3/4 up to 8hp, some smaller motors have bigger shafts for certain power washers and such, i find that an exception
redsox985
PA
My general rule of thumb has been ≤5hp = 5/8", 5-8hp = 3/4", ≥8hp = 1". As you can see there's some overlap in the general ideas, especially once you get way up in the hp range you get some >1" shaft diameters.
andyman5002
North West England! :D
So far, I think it's a Honda because-
*Fuel tank is correct size, shape, colour, trademark stampings, and (although missing) labels. Cap looks good, too
*Fan shroud is correct (UV faded) red, kill switch looks correct.
*Wire colour coding is correct, and so are the green rubber connector boots
*Throttle direction label is correct
*White choke lever
*Choke and fuel tap label looks correct
*Side cover castings, bosses, bolt holes and gussets appear correct
That's what I have so far. There are some difference that I have spotted, which can be attributed to age being different than mine. Recoil may be a clone replacement as contours and vent don't match mine, but again, could be the series too.
It is a tough one to judge. It sounds like its a really convincing clone or a genuine one with a few dodgy parts.
Not sure if its useful but the carb says its made in japan? Would a clone still have this stamp on it??
Andy
Is there a brand name on the carb?
Japan is a good sign- To my knowledge, all clone junk is Chinese. Japanese parts would e a higher quality and erg, more expensive. I'm not 100% sure, but there's a good chance a Honda factory carb is a Keihin, but don't quote me on that.
r_chez_08
Should be in the shop...
Cornwall, UK
You are right there toystory, honda carbs say "kehin japan"
I think my clone carb has a fake "K" symbol, but I cant remember.
I will check if you need to know.
andyman5002
Im going to work on it tomorrow, ive just primed the flywheel cover/shroud. Ill take some photos of the carb and post them. It said something else above the JAPAN bit but I cant remember what.
Clone or no clone Ill rebuild it and get it running the best I can. Main thing I wanted to know was the HP rating so I can get the correct parts. Im pretty sure its a GX340 based engine now after this info.
Once rebuilt its time to fab a frame :D
Thanks Andy
fowler
Bullsbrook West Aus
to me thats a honda
we have loads of those older hondas in our shed
as toystory said its all right
there should only be one long bolt though the middle though the rocker cover
also the oil fill/ drain caps are right
but the spark plup lead is differant
but that maybe the model
yeah- I saw the plug lead, too. I was wondering if it was different due to the age of the engine or perhaps it was replaced. Carb's interesting, I don't know what to make of that.
fowler
Bullsbrook West Aus
my google seach determins it to be chineze
http://hy21cn.en.hisupplier.com/
it does only say standard of japan not made in japan
EDIT
my diagnosis
bloke spills petrol on machine cranks it up and it burns
he thinks bugger ill have to make some money on this
so he gets a clone from the back of his shed and replaced all the burned parts
thats explains the replaced carby replaced spark lead and replaced startor
anything with plastic or rubber in it
kendelrk
redneck engineer
westland michigan
Ive got the same carb on my clone, defonetley a china carb, oh and thought I'd throw this out there, everyone says Honda and clone carbs are the same, there not, Honda has a bigger jet and smaller holes compared to the clone carb
Bluethunder3320
look at the gas tank where there used to be a sticker..
same placement as the honda in the picture i posted.
EDIT: usually clones have tons of stickers everywhere "warning warning warning"
andyman5002
Well whatever it is here it is now nearly finished after the rebuild:
