Identify My Engine
andyman5002
North West England! :D
Hi everyone, first post here :)
I was hoping someone could identify what engine this is? I think its a honda clone, maybe a GX340 clone? Its got a 1" output shaft.
Anyway heres some photos:
Theres no markings on it that I can see that state the HP or anything. I got it off ebay, its a runner but im going to rebuild it anyway and give it some paint!
Cheers Andy
kendelrk
redneck engineer
westland michigan
take off the air filter box, i beleive gx240/390 gas green air filters, looks like a genuine honda to me, take off the box, if its gray it might be a clone
andyman5002
The air filter has black sponge on the outside and yellow/cream fins on the inside, its not green :confused:
Theres no model numbers or markings anywhere. The only thing I know is that it was on a pressure washer. The shaft isnt tapered though :)
Andy
kendelrk
redneck engineer
westland michigan
weird, that makes it sound like a clone, but it dosent seem like it, grey is usually a clone color but this seems honda, look right under the kill switch on the flywheel shround
andyman5002
Ive started stripping it. I took the shroud off and cleaned it, didnt see any markings on there or on the castings. Ill have another look tomorrow, its dark now. I took some photos with the tank off and shroud off.
Does the 1" shaft mean its 11HP??
Cheers Andy
kendelrk
redneck engineer
westland michigan
1" shaft is used from 8hp up, this is either a gx340/390, you can clearly tell because of how the governor is being used in effect, this looks genuine honda, if you dont mind me asking, what did you pay for this?
andyman5002
How can you tell from the governor?. I paid £30 for it, or about $47. Is this a good price? I think its been stood outside for a while, the tank has started to rust inside and the carb has lots of rusty deposits in the bowl.
Andy
andyman5002
I see i see. I was wary about bidding on it because it was sold as unknown engine make or model. Seems good though. Ill get the head off tomorrow or at the weekend and see what condition the cylinder is in. It didnt smoke when running so looks promising.
I guess I can order genuine honda parts then if needed.
Not really related but what do you reckon is the best way of cleaning up the block without blasting it? Wire-brush? I want to get rid of that oxidisation.
Andy
kendelrk
redneck engineer
westland michigan
angle grinder and a wire brush, use to think it was stupid, i got one and ive loved the thing forever, its taken off plenty of paint and rust, itll take it rite off, and its good for parts, crankshaft, camshaft, flywheel and such, but im starting to see problems with this being a honda motor, for 1 the linkage isint right, the second thing is the OHV cover, its only got one bolt, there should be 5, throttle mount plate is off, looks to me like a cheaply made clone,
andyman5002
Oh well I thought it was too good to be true lol Ill still rebuild it, hopefully will be ok for a basic kart :) my first attempt so fingers crossed!
Im guessing its a cheap clone of the GX340. Im going to order a gasket kit I think maybe some new valve springs too.
Ill pick up a wire wheel too :)
Andy
kendelrk
redneck engineer
westland michigan
its a clone made for a pressure washer, as long as you have a good size of straight shaft, and it running, everything should work out great
Bluethunder3320
no the valve covers are supposed to have one bolt
really similar, its a close call, i might even say honda because the shroud is red and nothing looks different.
r_chez_08
Should be in the shop...
Cornwall, UK
Looks honda, with a clone recoil. However my 2 honda engines both have their model names and cc on them on the block (g100 and gx160). If it doesnt have that its probably a clone.
Do not visually compare this engine with the pic above. You are not taking into account that this engine is probably 20 years old, and the pic is of a recent engine.
I think there's a good possibility it's a Honda. My GX 340 had one rocker cover bolt, and the kill switch was on the front of the shroud.
Don't go by the air filter- Any engine that age had better not have the original air filter! Besides- the gree foam is only a pre-filter and would probably not exist after this long.
It looks like the recoil is a replacement, (expected) so don't go off that either.
Give me some time to compare to some pics of my '340, and I'll let you know what I think.
Oh- one other thing- the fuel tank appears to be the correct colour of creamy white, and you can see where the original ID sticker WAS on the tank.
So far, I think it's a Honda because-
*Fuel tank is correct size, shape, colour, trademark stampings, and (although missing) labels. Cap looks good, too
*Fan shroud is correct (UV faded) red, kill switch looks correct.
*Wire colour coding is correct, and so are the green rubber connector boots
*Throttle direction label is correct
*White choke lever
*Choke and fuel tap label looks correct
*Side cover castings, bosses, bolt holes and gussets appear correct
That's what I have so far. There are some difference that I have spotted, which can be attributed to age being different than mine. Recoil may be a clone replacement as contours and vent don't match mine, but again, could be the series too.
