No crank shaft bolt
Kyle
I just bought a clutch for my engine. Your supposed to put a bolt and a washer on the end of the shaft. The thing is, the shaft is solid (does not have a place to screw the bolt into). Do they make some sort of clip for this?
kendelrk
redneck engineer
westland michigan
no, but your clutch should have keyway and two set screws, one to hold onto the keyway between clutch and crankcashft, and one that touches the crankshaft to make sure it dosent slip
Russ2251
AZUSA:Powered by LAWN-BOY
Not necessarily.
Some clutches require a bolt, others do not.
The clutches that do not require a crankshaft bolt use set screws instead.
You have 2 possible options:
1.) Tap a hole in end of PTO to accept a bolt, or
2.) get a clutch that uses set screws to secure it to PTO.
Kyle
it does have a keyway with a set screw. but not sure about the second key way. Its a Hillard extreme clutch.
kendelrk
redneck engineer
westland michigan
i have a hillard will a built in keway, and then the set screw is on the keyway, i took it out, lined it all up then hit the set screw with the impact gun, never slipped a day in its life
Kyle
where did you get the clutch from? Northern tools?
kendelrk
redneck engineer
westland michigan
came when i got my mini bike a while ago, thing was slipping, pulled out the set screw and pushed it tight with the crankshaft as all my clutches are mounted imbored, took the driver for it that i have for my impact gun and hit it, never slipped on me, thats for sure
Boy howdy, are YOU gonna be kickin' yer own @ss if you ever have to take it out and it strips or breaks!:oops:
fowler
Bullsbrook West Aus
u could drill your own hole and thread it
and kendelrk im giveing u a 10 % chance of ever getting that thing out in one peice
my bet is it is already stripped in there and just wedged sideways enough to seize
Kyle
I drilled the shaft today. Tomorrow i will tap it.
Thanks for the help!
