IS there a way to make a pull start when the engine only has kick start
omar
im using it on a go kart and the engine is covered by the roll cage and i cant get my leg to kick start it
Bluethunder3320
no. you can spend a life time engineering a recoil to fit it, but realistically, no.
is it possible? yes, but like i said, it could be a life time journey. with the right tools, computer software, time, and experience, yes.
r97
Measure twice cut once
Massachusetts, USA
you can pretty simply extend the kick start lever. first bolt a second kick start lever onto the frame somewhere where you can "kick" it easily. then drill a hole in the kick start lever on the frame, and another hole in the same location on the original kick start lever (on the engine). connect both holes with some flat bar.
if done right it can work well. hopefully that makes some sense.
Try removing the kick lever and rotating it on the shaft into a better position.
Option2- Turn and extend the lever... Into a HANDLE! Option3- Modify cage to allow better access to kick lever. Option4- Spin-start engine- Place on jackstands, shift into second or third gear, switch on ignition. Grab tire, and spin.
Wait a minute- I thought you said you had a "normal 6hp engine" (your words, not mine.)???
omar
I got a manual atc 185 engine
HellSpawn
Wadena, Minnesota
I've always had the idea of using some splined shaft supported by bearings to bring the kickstart outside of the frame would be cool. I'm not sure where one could simply buy something with the right splines, but there are multiple other ways you could attach another shaft to the kickstart shaft.
redsox985
PA
I'd say try removing it and rotating. It should be splined with a small clamping screw.
Dead easy, and you don't need "splined shaft". Just cut the splined boss off the factory kick lever, and weld it to a length of tube. Before welding, cut a slot in the end of the tube, and align it with the pinch gap on the boss. Now that the shaft is extended, do whatever you like with it, including the bearings.
HellSpawn
Wadena, Minnesota
Good idea, I'll keep that in mind.
