computer software
Try removing the kick lever and rotating it on the shaft into a better position.
Option2- Turn and extend the lever... Into a HANDLE! Option3- Modify cage to allow better access to kick lever. Option4- Spin-start engine- Place on jackstands, shift into second or third gear, switch on ignition. Grab tire, and spin.
Wait a minute- I thought you said you had a "normal 6hp engine" (your words, not mine.)???
attatch a rope to the end of the kick starter and a handel on the other XD its easier and cheaper
I've always had the idea of using some splined shaft supported by bearings to bring the kickstart outside of the frame would be cool. I'm not sure where one could simply buy something with the right splines, but there are multiple other ways you could attach another shaft to the kickstart shaft.
Dead easy, and you don't need "splined shaft". Just cut the splined boss off the factory kick lever, and weld it to a length of tube. Before welding, cut a slot in the end of the tube, and align it with the pinch gap on the boss. Now that the shaft is extended, do whatever you like with it, including the bearings.
What? You dont need a computer.
