Ok, have read many threads which have helped me in my build. I bought a Thunder Kart frame with axles and sprocket and clutch included. Bought a 6.5Hp Predator from HF. My clutch has 10 teeth and sprocket has 54. Have 13" Tires(Though I measure them at 11").
Can not tell on sprocket or chain what size they are and from measurements it is to hard to differ from 1/8 and 5/32 to see if it is a 40 or 41...could be neither.
After running cart for about 5 minutes...at about 25 m.p.h. the clutch gets very hot....not smoking just hot to touch...about as hot as exhaust on engine...is this normal????
**Noticed today that it doesn't look like chain seats properly in the sprocket either....maybe these are different size sprocket and clutch teeth...they seem to measure the same though.
Thanks for posts on throttle linkage hook up and working on my kill switch now.
