Incorrect mag gap affects timing.
Please explain. Cheers
if its not adjusted right, it takes longer to produce a spark and the timing of the spark dosent agree with the rest of the engine so it dosent fire right
To a small degree, yes.so bigger gap = retards timing and smaller gap = advance?
•An armature air gap that is too wide will prevent spark. Not true. Well, sort of not true. Briggs & Stratton air gaps cannot be made too wide to prevent spark providing the coil is healthy and the engine is spun over fast enough. A wide air gap, say .030" will ever so slightly retard the ignition timing as the magnetic field takes longer to build within the coil windings
