Horizontal Conversion
redsox985
PA
I was thinking about how easy it is to rotate the clone recoils. IDK why it just hit me then. Now, does anyone know what will help it stay running longer?
sexyvicta
whenever i build a mower i usualy start it up before i bother putting the blade on etc to make sure it works. I've never had any problems running them without a blade/ blade disk
maybe im just lucky:D
redsox985
PA
a gas tank? sounds like it only starts off the gas in the spark plug hole.
The carb was full so it should run a little longer. Have you ever shut off the gas on a clone and just let it run? It goes for a minute or so.
Well, I know that it SHOULD work. It ran when it was given to me. :(
karl
North east Ohio
Your getting an air leak through the carb. You need a o-ring for the carb to seal around the intake tube, try to make a ridge in the carb and put the factory o-ring on from the briggs carb. Or to make things way easier, use the original carb and gas tank.
Bluethunder3320
sounds like the flywheel is too light.. let go of the throttle and it instantly shuts off.
as for the sucking noise i have no idea
redsox985
PA
Well yea the flywheel is going to be light since it's a mower engine but I thought it's been concluded these can run with just the light fly wheels.
redsox985
PA
Could that white smoke be from the carb leaking?
The carb leaking which way? That gets shot out with some force very quickly. I think it may need a new plug too, as this is the original and this mower saw lots of use.
redsox985
PA
If anything I think it may be some type of decompression. Maybe Russ will chime in. Anyways, I rigged up a little air cleaner from a piece of dust mask and sheet metal. I'll try playing with it soon hopefully to see if this will cause it to run a bit richer.
r97
Measure twice cut once
Massachusetts, USA
not really sure if this is at all the case, but for some reason its nagging me this could be the cause. are you sure the camshaft is timed correctly? seems to me like maybe the intake valve is open on the exhaust or compression stroke.....
decompression would come out the exhaust right? i suppose you could try a new plug too, wouldn't hurt.
B.M.800
TheBeal.
Central PA
Hmmm... riding mower 2 cylinder... gives me a great idea.
:devil2:
I wonder how difficult that would be to set up?
