How far can it go, tilted motor.
B.M.800
TheBeal.
Central PA
I recently got a baja heat mini bike, also an 11hp B&S... See where Im goin?
The briggs wont fit strait up, but it will fit at an angle... My question, how far of an angle could it run good at without modification?
Thanks.
oscaryu1
5HP's were run at 15 degrees on karts for some applications. Only difference, more oil.
B.M.800
TheBeal.
Central PA
Well... Im thinking it would be more than that. If it comes down to poop, I could modify the oil flingermabob...
CaptCanadia
Acton, CA USA
Wouldn't go over a 25 degree angle, the oil slinger has problems "picking up" the oil past that angle.
You can always mod that easily. Just get a small piece of metal to put and and bend it a bit. If it's longer it will pick oil up easier. Just be careful it doesn't wack the side of the engine.
That is a harsh angle and I'm not sure it would even start at that, but you can always try.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
You cant really make it longer, theres hardly any room around it in the first place.
CaptCanadia
Acton, CA USA
In most B&S there is enough room to make it longer. I saw a guy convert a vertical to horizontal and he made it longer by quite a bit and it worked like a charm.
CaptCanadia
Acton, CA USA
His did lol I could even go back and find the video.
EDIT: I don't think it was an oil slinger what it was something that turned the oil though. He removed that and added a piece of metal.
r97
Measure twice cut once
Massachusetts, USA
a vertical Tecumseh i have has a small, extremely simple oil pump rigged up to the camshaft that pumps oil through passages to all major parts of the engine. i think the proper term would be "forced splash lubrication", its pretty neat.
B.M.800
TheBeal.
Central PA
Im thinking it would be more than that... Assuming its innards are identical to a 5hp briggs, I have one with no crank case cover, tilted it to about what I think what would let the 11hp fit, the oil level I would think would be up to the crankshaft no problem... that a issue?
Thanks.
Thanks.
I think he biggest issue will be figuring out how much oil to use, cause you probably dont wanna pour in too much.
Once you figure out the exact angle you need the engine mounted: I'd pop the side cover off and note how deep the oil dipper was originally intended to reach down into the oil when the engine was sitting flat and full of oil. (then scratch a mark on the dipper for reference)
Then with the side cover still off, tightly wrap the lower half of the block with Saran wrap, tilt the engine to your desired angle, and then pour oil in to see how much it takes to ensure the oil dipper is reaching in as deep as it was originally intended.
If your side cover is dished-out where it would add to the oil capacity, you could also wrap its lower half in Saran wrap, turn it to the same angle, and pour oil in it to learn how much additional oil to use.
You'll need to find some type of large measuring cup/container with once-labeling and pour your oil into that first, so you'll know for sure how much oil you've poured in during your tests.
Then once you've got the engine all back together with the correct amount of oil and sitting at the angle you need: Find something you could use as a dip stick, stick it in the oil fill hole and then use a hacksaw blade to mark your dipstick with your correct oil level for future reference.
Have you considered how a severe engine angle might affect your carbs float-level?
redsox985
PA
As long as you use quart bottles, you can get a pretty darn accurate approximation from the little gauge on the side.
B.M.800
TheBeal.
Central PA
Alright, I try an get a picture of the 11hp positioned in the mini bike frame... see what you guys think about it.
