semi-automatic transmission
project
hi all,
i am new and all and don't really know if i posted in the right place.
i am planning on building a full-suspension kart/buggy as a school project but I have some questions.
so here it goes..
Can a semi-automatic transmission taken from an old honda 70-80cc be used with a larger engine maybe 125-200cc ??
the-cyborg
Spring, Texas
Well an old Norton, BSA, Triumph would, but good luck finding one for a reasonable decent price, as they are highly sought after.
here is a Norton Matchless gearbox http://cgi.ebay.com/ebaymotors/Gearbox-Transmission-Norton-Matchless-AJS-91-_W0QQcmdZViewItemQQhashZitem2eb69403e8QQitemZ200631649256QQptZMotorcyclesQ5fPartsQ5fAccessories
and
here is a Triumph Preunit gearbox http://cgi.ebay.com/ebaymotors/Triumph-Preunit-Transmission-Gearbox-Norton-BSA-TR6-T10-_W0QQcmdZViewItemQQhashZitem2eb6981d6bQQitemZ200631917931QQptZMotorcyclesQ5fPartsQ5fAccessories
But it wouldn't surprise me any if they for no less than $400 to $600
Harley 5 speed http://cgi.ebay.com/ebaymotors/HARLEY-DAVIDSON-5-SPEED-TRANSMISSION-COMPLETE-_W0QQcmdZViewItemQQhashZitem2a12601544QQitemZ180696913220QQptZMotorcyclesQ5fPartsQ5fAccessories
Harley 45 series http://cgi.ebay.com/ebaymotors/45-complete-transmission-_W0QQcmdZViewItemQQhashZitem2eb698975aQQitemZ200631949146QQptZMotorcyclesQ5fPartsQ5fAccessories
So as you see this rout may not be the way you want to go
You might be better off finding an old air cooled 4 stroke bike and using the entire motor and trans off it.
the-cyborg
Spring, Texas
Also I do know that peerless makes some automatic riding mower transmission such as the 205-024C but they are high as crap too and made for vertical shaft engines.
perhaps even look into snowmobile engines
will1384
The GY6 motor that's on a lot of Chinese ATVs, scooters
and go-carts, has a CVT Transmission that is like Comet
torque converter, the GY6 CVT has a driver and a driven
pulley, both are removable, but from what I have seen
they fit onto a shaft that has splines.
BTW the GY6 is a clone of a Honda motor.
project
thanks for the input guys really helped a lot. as you can notice i am not familiar with engines and transmissions and how they work.
for now i am trying to get the picture of what i can used and how to do it (building and making a kart work) before going to the drawing board.
I saw this engine http://maltapark.com/item.asp?ItemID=938055 and was wondering if it was good to used on a kart. the seller state it is a 9hp and runs.
sideways
Unfinished projects king.
Perth, Western Australia
Yes, it is possible but it's one of those if you have to ask how then you probably can't do it kinda things.
There's a few ways you can do it.
First way is to remove the flywheel cover and flywheel, machine an adapter to fit a sprocket there. Remove the barrel, head, conrod piston ect and make a blanking plate to go there. You'l have a fair bit of vibration but nothing too horrible.
Another way is the same as above but machine up a bar to go in place of the crank, this way you don't get the horrible imbalance.
It's all kind pointless though, a CT70 engine would be just as quick as a 6.5hp clone anyway.
You should get them to send you some pics and dimensions of that 9HPs shaft, other than that it looks okay.
Thanks
Hayden
sexyvicta
yip you're spot on there. I've been keeping my eyes pealed for a g box to match a matchless g80 engine i have. They use the same gear boxes as verious triumphs etc.
over here they seem to sell for $200-800.
$200 = a box full of parts from a box that some guy took apart 30 years ago, which may or may not = a complete gearbox :D
