clone ungoverned?
kendelrk
redneck engineer
westland michigan
well im going riding when it cools down a bit, and was wondering, i used to run the engine maybe an hour, or two at a time, can i still run the engine for that long with the governor out? or do i have to let it cool down after like 20 minutes? or can i run it like i used to?
Russ2251
AZUSA:Powered by LAWN-BOY
Giving an engine a rest does nothing to restore or preserve it's life span. Life span is given in hours of use.
A typical small engine reaches full operating temperature in just a couple minutes...meaning that it is right back up to where it was before it was given a "rest".
kendelrk
redneck engineer
westland michigan
i havent clipped it yet, because i do keep enough oil in my engine, but if it serves problems im loosing the oil sensor, and all i run is 10w-30
Was oil level sufficiently high?
Spec on the GX and clones is SAE 30 in the "normal" range, and 10W30 if temps get low enough. Living where I do, and riding year 'round, I always have run a quality 10W30.
kendelrk
redneck engineer
westland michigan
well i was taking a ride just a minute ago. when i let off the throttle its dieing. and i have to choke it and give it gas to start. then i take it off choke and it either dies or backfires and its fine. until i let off the gas when riding. if it starts to die and i press in the gas its just fine. is it my jet? btw. stay away from a hot exaughst or youll get a nice burn
You shoulda got the upgraded muffler- the one that has, "Caution- Hot!" stamped into it. I got that one. Thank goodness- I'd hate to get burned! Now that I have this knowledge- want to buy my muffler?
If choking it helps, it would seem to be starving. Start with the basics- lots of gas in the tank? Clean, fresh, filtered fuel? Carb bolts tight?
Aside from the governor, what have you done to the engine?
Bluethunder3320
muffler burn? lol.
i just had to share.
make a heat shield like this!!!!
dave1701
Good for 100,000 Miles
MICHIGAN
You ride in the winter? Isn't that pretty cold? However, riding in the snow and Ice sounds fun.
kendelrk
redneck engineer
westland michigan
its on my kart blue, i walked around and burnt myself, and choking does help, it has high flow air filter and exaughst, and a 90 jet it helps to have the choke about half, but the biggest problem is that i just blew my tire
