tacometer
dictionary6767
Nj
were can i get a tacometer? how do I install a tacometer? i want it to be a big silver one not digital but a gauge. do you know were i can get one? i also want a a speedometer thats a gauge were could I get one?
anyone, make one for a 4 cycle motor??????
4-cycle? Yes! The one in my truck!
Unfortunately, analog tachs for 1,2, or 3 cylinder engines are pretty hard to come by. IIRC, on the home page of this website, there is a link to a how-to on converting an aftermarket automotive tach for single cylinder duty.
redsox985
PA
Taco Bell? :roflol:
Here's my tacometer.
The less time it shows before my first bathroom run, the more tacos I ate.
supermanotorious
Winchmaster 5000
New River, AZ
where is this article? I've searched the homepage
Clint Burleigh
Photographer
Houston, TX
Here is the tach mentioned above. It comes with an inductive pick-up that you clamp on the spark plug wire. I tested it out on a HF 6.5 HP engine. My local oreily's had it in stock.
This is your best bet. I too did not want a digital reading and this is the cheapest analog tach I could find.
Justin9
Quitman, GA
If you wanted to spend the time, with some resistors or a pot, you can re-tune the car analog tach to work with a single cylinder... but you would need something to compare it too... like a tiny tach or something that was a known good tach so you could dial in the resistors, or the pot (which would be easier in my opinion)
