The Hillbilly Motorized bike of awesomeness
karl
North east Ohio
I made this thing in less than an hour :roflol: I need a throttle cable. I can Idle the thing around the yard at about 10mph and use next to no gas. Only thing is its so hard to take off. 3hp briggs. Total cost- $5 for motor
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Why did you weld the peg on? And what pressure are you running that back wheel at to allow it to get squished like that?
karl
North east Ohio
I am gonna improve it alittle. Move the motor back alittle, better rear tire, a motor mount brace, and some spray paint.
bighead
Pacific Northwest USA
Make a slot on the peg for the axle will slide out. Use an extension to get the rear wheel hub bolt off thru the middle of the peg.
If I am seeing it right it will work great.
porsche930dude
Upstate, NY
dude thats a vintage diamondback you could have bought a real minibike for what you could have sold that for. frames probrobly worthless now that you botched it up but the other parts are woth good money man
karl
North east Ohio
Not really. The rear rim is not factory, the front rim is wobbly, the handle bars move back and forth when fully tightened, stickers are peeling on the frame, scratched up plus beat up, mismatched peddles, 3 rivets gone on front sprocket, no front brakes, crappy rear, ect. Might get like $20 for the bike if that so Its not really worth it.
Ghanem
United Arab Emirates
Why didn't you weld a sprocket in the rear wheel ?
like this
sexyvicta
I don't think thats welded. I think its a bolt on sandwich plate thing that comes with that kit.
this
plus this
im going to get one once i find a bike to put my h25 on
jrmints1415
Naperville Illinois
i think that it is a great idea to use that engine on a bike but honestly?? I know you said it was hillbilly but dang!! you might as well use a piece of string as the throttle cable because that is about as long as it will last. I dont mean to be harsh but i honestly think it a waste of an engine with that low of support underneath it... remember that it's quality not quantity.
Badot
Working on a motorized bike of my own, just need to get a little more cash for steel for a rear rack mount... I'm using chain drive and truing up the sprocket on the back is a pain in the butt, not to mention it's much easier to get a higher ratio with a friction drive like Karl did. And no, you can't just weld the sprocket onto the back (at least not on a standard bike)
On the other hand, chain drives give you higher speed and better economy (since you don't have to ram the roller into the tire) and your tires last longer.
Question though, does the drive slip at all when you're pedal starting it?
And Blue -- I think the torque from the power stroke of an engine is more than enough to damage a bicycle sprocket.
karl
North east Ohio
I built it and the motor mount is plenty strong. I had my 170 lbs buddy jump on it and hit it with a sledge and it did not budge. It will last awhile. Even if the engine would fall off- witch there is no chance of that happening- it would fall on the grass and be unaffected. Why not use a 3hp briggs on a bike? There are bulletproof. It will out run and clone easy.
Point being- Get your facts straight
You cant pedal start it. To hard. I set it engine on something so the tires off the ground and pull it. One I get a kickstand on it it will be easier to take off.
