whats happening?
kendelrk
redneck engineer
westland michigan
so yestreday well runing my mini bike eveything was fine, the engine had a little bit of water on it from riding after it rained but i wiped it off, now today when i went to ride over to my aunts with somthing for my mom, it sounded like something was scraping or rubbing in the engine and it sounded really bad, whats wrong?
kendelrk
redneck engineer
westland michigan
its coming stright from inside the motor, and its a clone, its coming through the crankcase, and ill have to check on that russ
kendelrk
redneck engineer
westland michigan
i dindt hear anything, so i took off the shroud down to the flywheel and turned the engine, and nothing, which is starting to make me think something with pull start
Have you already tried lubricating your clutches bushing or bearing? They can make horrible noises when they need to be lubed. (especially if the chain is adjusted too tight...)
____________
Most automotive mechanics own a stethoscope like this to help locate the source of noises like yours. Maybe you should consider buying, renting or trying to barrow one:
___________
You might be onto something there. See if you can figure out a way to start the engine with the pull start removed.
But if not:
I think I'd try loosening just the 3 bolts that hold the round pull start cover on,
then I'd start the engine and just let it idle,
then while very-carefully holding this cover in place, remove those 3 loosened bolts and slide the pull start assembly straight off to learn if the noise suddenly stopped or not.
I've never tried this on a clone and it might be a very dangerous task. The pull-start might catch on the running engine and start violently spinning, so proceed with caution.
A much safer method of this same test would be to purchase 3 extra long pull start cover bolts (like 3" long) so you could leave them in place and slide the pull start assembly out and away from the engines spinning shaft after starting...
kendelrk
redneck engineer
westland michigan
what i did is have my grandfather hold the pull start on, i started it and then we pulled the pull start off, that wasnt thr problem, and ill try that anderkart, would wd40 be enough? and whats the exact name of the tool?
oldbikerarlo
Old guy
Marana, Az.
I got sand in my clutch the other day, it made a scraping sound. Took the clutch bell off and blew it out with compressed air, and used some 3 in 1 oil on the bushing while it was apart. Reassembled, and its good as new.
kendelrk
redneck engineer
westland michigan
so should i just take off the clutch and see what goes from there? and i might there doing construction on the street and im not exactley non rough on it
kendelrk
redneck engineer
westland michigan
well in trying to take the clutch off nothing, but did oil it with crankcase oil, its missing one of the engine holding bolts, so what i did was had my little brother sit on the gas tank and no noise, but i did notice that since i oiled it it hasent been having the power it had
kendelrk
redneck engineer
westland michigan
well got the shaking under control, no noises, looking all good, but heres the new problem after oiling the clutch and getting some everywhere. everytime i ride, it starts to smoke
