The Exile
atheros101
Ok so im working on my custom cart i have modded it so i get 50% more air and 30% more Torque it is a 3hp briggs and stratton but i did all the work myself! thanks for viewing
Scroll down until you see my go kart
r97
Measure twice cut once
Massachusetts, USA
try this:
save picture as a "jpeg"
click "post reply" (do not use quick reply!)
scroll down until you see "manage attachments" click on it, a new window should appear
in the new window click the "select file" (well, its something like that..) button, another window should appear
find your image and select it in the window that popped up in the previous step
click the "download" button (i'm pretty sure its the download button...)
write something in your post, click the post reply button.
atheros101
The Exile with pictures
Sorry i couldnt get them to post from online
redsox985
PA
I can't say I'm a fan of your welded galvinized exhaust. Is that welded straight to the block? It's a nice little flat head though.
bighead
Pacific Northwest USA
Also how did you seal the airfilter to the box? Good idea if it works well.
Tell us more about what your trying to do. You will get some good help here to make your kart run well.
Atheros101, i have pretty much the same engine as well. Do you find that you have to constantly top up the fuel tank because it is so small. I find that my kart also stalls a lot because when the tank gets low, the pipes that go into the tank from the carb do not make contact with the fuel when you go over bumps. It seems to suck air, and then dies. It is really annoying!!
atheros101
i Used the old air filter and the air filter then i added a new filter and used the base of the old air filter on the bottom and used some stuff to stick it together but i forgot its name and i made the striaght pipe out of scooter handle bars and i did some work to the engine to make the torque go up and i broke the clutch drifting a corner somehow but landuse i had really bad troubles with the same thing but i made the tubes in the tank bigger but i didnt have problems with bumps
atheros101
O and the pipw comes right off when u unthread it out but it looks like its permenetly on there but its not
