whipped cream nitrous oxide??
migel101
south america
has anyone heard of this working??
or anything to add about this? all i know about is basically whats in the vid. there seemed to be some vague comments about this working a few places on the web: nothing against it, but not much for it :huh:
im not in an area where prepared whipped cream exists commercially :worried2: otherwise id just try it.
http://www.youtube.com/watch?v=hi_pr-kIlmk
Bluethunder3320
personally i think it doesnt do much.
apparently some of the propellant in the can is very flammable, sometimes it probably is, but some formulas are going all eco-friendly and not as much is so flammable as before.
its probably just the burst of air.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Ive heard of people getting "high" off the N20 in canned whipped cream. i doubt it would be anything noticeable, plus you'd have to be careful not to get whipped cream in your carb.
Badot
Pretty much bull****
With real nitrous oxide systems you're pretty much injecting straight liquid into the manifold/intercooler/wherever you decide to. And that liquid then expands to a massive volume compared to what it was. All in all you'd be getting very, very minuscule amounts into the engine.
From there you have the concept of how it actually works - for one, the expanding liquid to gas cools the intake charge dramatically (for higher density). In this case 99% of the cooling would go straight into the can walls and whipped cream. Second, when the nitrous is heated (as in during the compression stroke) it releases oxygen, which allows the engine to burn more fuel. Meaning it would need to have the carb pumping in more gas or a separate means to deliver it.
Not to mention the change would be incredibly easy to fake.
sexyvicta
you buy the n2o charge canister thing. it dont have whipped cream in it.
sexyvicta
why? edit: for toluene?
when i was like 12 i put meths + petrol + turps mix in lawnmower haha. It ran
Bluethunder3320
i found 2 Co2 cans for airsoft guns at school and i took them. still dont know what to do with them...........
redsox985
PA
Whippets!
Did I not say whippets a while back? These things may actually do something.
Are they the finger sized tanks like posted above because CO2 airsoft guns usually run those. The bigger 16 or 20oz tanks are usually paintball. The 20oz tanks can also be used for MIG/TIG welding.
While we are on the subject, has anyone tried a capful or so of two way thinners in the gas tank?
I have no clue what "two-way thinners" is, but I read somewhere that adding a small measure of Acetone to your gasoline greatly increases economy. No idea if it's true.
Bluethunder3320
yeah they were small enough to put in my pocket. my paintball CO2 tank isnt allowed to be filled because its like 10 years old and the paintball company needs the date of manufacture because supposedly my tank is unsafe now.
