Hello, I am new to this site and plan to build a yard cart/go kart with my daughter and would liek to know what type of engine you would suggest, I have a HOnad 690CC Horizontail engine, would this work?
If this:-->
http://www.smallenginewarehouse.com.../16" Shaft, Fuel Pump, Oil Filter, Oil Cooler is your engine, Your going to run into problems because it has a 1-7/16" diameter output shaft, and you wont find any clutches or torque converters that would fit and bolt right on.
Although as one solution, you could remove the crank and have a machine shop turn the cranks output-shaft portion down to a standard 1" diameter, and also have them broach in a new 1/4"-wide x 1/8"-deep keyway.
This way any 1"-bore centrifugal clutch or torque converter system that was designed to withstand at least 22hp could be easily installed/used on a kart.
Here's a thread/video of a kart with an engine similar
(but just a little smaller) than yours:
Thread here:-->
http://www.diygokarts.com/vb/showthread.php?t=6944
Warning turn down your audio if you're easily offended or a minor, this video contains strong language! http://www.youtube.com/watch?v=7bmOLhIlpKQ
Thank You All for your Hhelp My Daughter is 9 and by the sound of things is I maybe getting in to deep, this is my first kart and I thought the bigger the better... Any thoughts on where to purchase components or another engine, i am not concerned so much with cost as I am of quality and ablilty to truly abuse this "Yard Kart".
I think you should use your big engine to build a kart for yourself
(you'll find that 2 karts riding around together is much more fun than just 1 by itself...)
But If you wanted the highest quality engine for your daughters kart, I'd suggest something like this:
http://www.smallenginewarehouse.com/product.asp?PN=GX200QX&desc=Honda
(6.5hp Horizontal 3/4"x2 5/16" Keyed Shaft)
Most any 6.5hp engine would be
way-overkill for a 9 y/o beginning kart rider, but you could gear it way down, and then also adjust the engines
(governor/throttle-linkage stop) limiting screw to lower rpm/top speeds to most any that you wanted.
And then as your daughter aged and her driving abilities increased, you could easily re-adjust the max-rpm higher and higher, and then also re-gear her kart to achieve much higher top speeds so she wouldn't ever get bored riding a slow kart.
ps:
(with adding available speed parts, you could achieve as much as 20hp out of that little GX200 engine. so in a few years, her kart could keep up with yours if you really wanted...)
