Honda Engine??
stbrooney
Hello, I am new to this site and plan to build a yard cart/go kart with my daughter and would liek to know what type of engine you would suggest, I have a HOnad 690CC Horizontail engine, would this work?
stbrooney
If I stick with this engine I have, would it "fly" meaning dangerous? I thought if the cart weight a couple hundered pounds it would ride more like a golf cart...
Bluethunder3320
true, you could make it heavy... then it would be a tank!
690cc is massive for a kid's kart, heck even an adults kart, just saying, safety first. check what the shaft diameter is and if its keyed.
do you know the horsepower rating?
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
You could use your engine for the kart but i have some recomendations...
*Use a torque converter instead of a clutch
*Put some decent sized tires on it, and gear it low for torque and acceleration
*Make it a two seater and build it really well
*Dont cheap out on parts, that engine is really powerful and it has the potential to be really dangerous if you dont use good parts like high quality bearings and a strong axle, etc.
* the engine itself probably weighs alot already so thats a start. lol
Do you have any pics of the engine? Have you started the frame yet? For a motor that big id gear it for offroad use and def. put some suspension.
Welcome to the forums!!
Or you can do what blue said and go with the smaller engine :)
Quite honestly, that's an insane amount of engine for the purpose. Sure, you could add a ton of weight, and gear the wee out of it- kinda pointless really. If something does go wrong (and with kids it will), that thing will be an absolute bulldozer. Geared that low, it not only threatens life and limb, but some pretty impressive property damage, too. In my opinion, either reserve that engine for another project or sell it to fund this one. It is a valuable engine. More suited to the task would be something more typically in the 3-6.5hp range and can be had rather cheaply.
Welcome to the forum!
redsox985
PA
3-6.5 HP equates to 200cc or less. A 5 HP is usually 125 cc and a 6.5 HP is usually 200cc. With 690cc's geared as low as you'd want it so that it goes slow enough for the kids, you could probably tow a car with it.
lycsailor17
way, waaaaaaaaaaaaayyyyyyyyyyyyyyy to big. I quickly looked around and found its 24 hp. That go kart will be able to pull a car, or do 65 on the turnpike.
Not probably, definitely. Hence my concern about a runaway kart.
And that's with the optimistic assumption that nobody gets hurt. I know I've gone Safety Gestapo here, but once you've seen what you can do with a few horsepower and low enough gearing, it'll scare you sober. I have an old 30hp agricultural tractor that absolutely blew my mind- I hauled an 8000lb industrial tractor out of a snowy ditch with it. I did a two-minute-long catwalk hauling that pig out, and my nerves were going to give out long before that old Dexta would...
At any rate, don't anyone think that slow automatically equates to safe.
stbrooney
Thank You All for your Hhelp My Daughter is 9 and by the sound of things is I maybe getting in to deep, this is my first kart and I thought the bigger the better... Any thoughts on where to purchase components or another engine, i am not concerned so much with cost as I am of quality and ablilty to truly abuse this "Yard Kart".
If this:--> http://www.smallenginewarehouse.com.../16" Shaft, Fuel Pump, Oil Filter, Oil Cooler is your engine, Your going to run into problems because it has a 1-7/16" diameter output shaft, and you wont find any clutches or torque converters that would fit and bolt right on.
Although as one solution, you could remove the crank and have a machine shop turn the cranks output-shaft portion down to a standard 1" diameter, and also have them broach in a new 1/4"-wide x 1/8"-deep keyway.
This way any 1"-bore centrifugal clutch or torque converter system that was designed to withstand at least 22hp could be easily installed/used on a kart.
Here's a thread/video of a kart with an engine similar (but just a little smaller) than yours:
Thread here:--> http://www.diygokarts.com/vb/showthread.php?t=6944
Warning turn down your audio if you're easily offended or a minor, this video contains strong language! http://www.youtube.com/watch?v=7bmOLhIlpKQ
I think you should use your big engine to build a kart for yourself :thumbsup:
(you'll find that 2 karts riding around together is much more fun than just 1 by itself...)
But If you wanted the highest quality engine for your daughters kart, I'd suggest something like this: http://www.smallenginewarehouse.com/product.asp?PN=GX200QX&desc=Honda
(6.5hp Horizontal 3/4"x2 5/16" Keyed Shaft)
Most any 6.5hp engine would be way-overkill for a 9 y/o beginning kart rider, but you could gear it way down, and then also adjust the engines (governor/throttle-linkage stop) limiting screw to lower rpm/top speeds to most any that you wanted.
And then as your daughter aged and her driving abilities increased, you could easily re-adjust the max-rpm higher and higher, and then also re-gear her kart to achieve much higher top speeds so she wouldn't ever get bored riding a slow kart.
ps:
(with adding available speed parts, you could achieve as much as 20hp out of that little GX200 engine. so in a few years, her kart could keep up with yours if you really wanted...)
redsox985
PA
How about we just don't listen as there's little valuable audio? We've all been on YouTube and know what's on there. It's a good demonstration of what the motor is potential of and helps convey that it's WAY too big for any kids kart. Unless you hate your kids. Anderkart, maybe just put a little note above the video saying something about the harsh language in the video. Although, I do appreciate trying to keep it clean around here as karting can be a family event.
Ten-4, :censored: but you realise that'll just make the kiddies wanna hear it even more, right?
Overly shelter yer kids from from the cesspool of the real world and they'll just dive in the deep end the first opportunity they get...
