Relying on valve float as a limiter?
Badot
So I decided that I may want to remove the governor on my trike (Greyhound 6.5) and possibly regear it for more low end torque (or maybe just leave the gearing for a theoretical 55 at 5000?)
Anyways, since I drift this thing through almost every corner, I was looking for some way to govern the engine at a higher RPM so I don't over-rev it when the wheels start sliding, but as far as valve float goes I've heard people say everything from it being perfectly safe to the piston smashing the valves and the carb blowing off... any thoughts?
Or am I just being stupid and missing an obvious way to adjust the governor to cut at maybe 5000ish (probably closer to the upper 4000s) revs? I haven't had one apart yet, but I prefer knowing what I'm doing before tearing things down and possibly breaking something.
Bluethunder3320
i took the governor out of a clone before and it never ran except for idle on choke. have you tried unscrewing the throttle stop a little first?
Badot
What throttle stop? :D
EDIT: Russ, just to clarify, are you saying it should be fine?
Bluethunder3320
your connecting rod going right through the side of the block.......
or a flywheel explosion but that is still myth.
karl
North east Ohio
I had a pushrod on a briggs ohv lawn mower engine go through the block-head. But on a go-kart no governor is ok because the engine is under more load and you can control the throttle alot better.
Clayton
Saskatchewan, Canada
I bypassed the gov on my clone, it works great, I would feel safer doing it on a Briggs flathead, but I think that if you aren't revving the piss out of it you will be okay.
