This looks sexy!! 335cc Rotax engine
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
i cant just hook up a straight pipe???
Back in the good old days (the early 1900's), before Walter Kaaden developed the expansion chamber, all 2 strokes ran straight pipes. Tuning was easy, you started with a long pipe and progressively cut it shorter until the engine ran well at the speed you wanted. The exhaust scavenging effect was less pronounced and had a very narrow rpm range, but it worked.
The short answer is yes, you can hook up a straight pipe. Russ uses VW megaphone exhaust tips, which not only look super cool, the megaphone shape (a divergent cone) creates a larger & more useful negative pressure wave to help scavenge the cylinder.
:iagree:
Your post reminded me of my old Maico 501cc motocross bike I used to have back in the stone-age. It had a huge down-pipe chamber and one day the chamber broke off in half about 18" back from the engine. It broke off flush at the largest point and basically ended up being a 5" diameter outlet megaphone, open header.
The engine had so much dam power to begin with that it was kinda hard to tell any difference but after the chamber broke it seemed to have lost a bit of its low-end, but still revved strong at the high end. The biggest problem I remember after the pipe broke was that it was so obnoxiously loud it made my ears ring :D
That Maico was a freakin rocket ship and was still WAY faster than all my buddy's 250 motocross bikes even with the broken chamber.
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
thanks for the link anderkart, they really helped.
I think ill get it. If the craigslist poster ever replies to me that is. Its only 30 bucks and if in the end i dont end up using it ill probably just keep it in the shed until its worth something and just sell it.
What ill do if i end up getting it:
1- Get a clone carb like this one
http://cgi.ebay.com/HONDA-GX390-13-...318?pt=LH_DefaultDomain_0&hash=item20b869d626
2- Make an exhaust
3- New spark plug
4- gas tank
5- Pull start
Does this sound good??
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
You had a Maico 501? How are you not dead, or dismembered? I love those big old 2 strokes, Yamaha IT 465's and YZ 490's and Honda CR 480's stand out in my mind from my misspent youth, drooling over dirtbike mags in the school library :D
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
bighead
Pacific Northwest USA
Try searching 340 Rotax. even though the cc are 355 on the engine. Most makers listed the models as 340cc.
I could be wrong in this case. But lots of makers up the size.
See if you can find one on ebay in active and completed listings. Good way to tell value on vintage sled engines.
I would guess the vintage to be 70's from just looking at it.
Looks like a 30mm tapered shaft. You can buy a 30mm taperd shaft clutch. Then find a sled driven clutch to fab into your kart. If you went with the yamaha enticer clutch and driven. The cost would be right around $100.
Does he have the intake manifold?
Double check the shaft size. I could be wrong.
bighead
Look here
http://cgi.ebay.com/ebaymotors/Vint...76029204QQptZSnowmobileQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Vint...76032505QQptZSnowmobileQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Rare...25542138QQptZSnowmobileQ5fPartsQ5fAccessories
Find out what sled your motor was used in originaly. Probably a few brands being rotax. Then try searching for parts under the brand and model name. You will get more hits. For example they used the 335cc in the Ski Do Olympique models
j.concepcion54321
East Providence RI
The silencers in your link are just mufflers and will probably work, but won't provide any sort of power increase or tuning benefit. You need a tuned expansion chamber & matching muffler to get the most power out of that engine, and a slide type carburetor instead of a utility engine carb.
those links that you gave me have some decent prices. would those work good on the engine?? total i will have spent around 100 bucks on this engine.
IM willing to do it if this engine is good. so for 100 bucks would this be a good but for a 335cc engine??
bighead
That carb in the link is to small. You need like a 36mm or abouts. The pipe would work well. Would be loud though with no silencer.
Here is a motor with a home made expansion chamber. Not sure how it works for I have not ran it yet. I would run a expansion chamber pipe though. This moter was in a Odyssey project I picked up. The pipes are facing the wrong way in the pics. They did this to make room for the seat. Well made just not sure how a box will work for an expansion chamber.
EastCoast
Nova Scotia, Canada
hey I found one of there motors today and got it for free.
Not sure how to start it or where to start fixing it up? I would like to use it on a kart if I could.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
hey I found one of there motors today and got it for free. Not sure how to start it or where to start fixing it up? I would like to use it on a kart if I could.
Nice score! Looks like the recoil starter is missing. However, you could do the old wrap-n-pull start with a piece of rope. Crankshaft rotation will be clockwise, when veiwed from the flywheel end. Let us know if it starts!
PS: that muffler looks horrible, I'd ditch it as soon as possible
EastCoast
Nova Scotia, Canada
Yeah the pull start housing and cord is missing, I been looking online for one but can't find one yet.
LOL yeah the muffler is horrible not sure who tried to weld on it but not a good job.
I want to try to run it this week some time.
j.concepcion54321
East Providence RI
hey let me know if you can get it started and how it runs. if it runs strong and its worth the investment then ill take it.
say... would you mind... gee i dont know.. maybe giving me the carburetor :D
j.concepcion54321
East Providence RI
yeah i checked out your build thread east coast, and if you can get that motor running id use it instead of the honda 3.5hp.
as for my situation, i think ill use the 30 bucks to fix up my briggs nice and use that on my kart instead. im still waiting for the craigslist poster to reply to me and if he does ill take it but as of now i think hes not gonna reply so the moneys on hold for now and ill giv him another week. if he comes thru then awesme, if not then im fixin up th briggs :D
