The Mechtician
Gargamel Jr.
Back in the good old days (the early 1900's), before Walter Kaaden developed the expansion chamber, all 2 strokes ran straight pipes. Tuning was easy, you started with a long pipe and progressively cut it shorter until the engine ran well at the speed you wanted. The exhaust scavenging effect was less pronounced and had a very narrow rpm range, but it worked.i cant just hook up a straight pipe???
The short answer is yes, you can hook up a straight pipe. Russ uses VW megaphone exhaust tips, which not only look super cool, the megaphone shape (a divergent cone) creates a larger & more useful negative pressure wave to help scavenge the cylinder.
