I May Kill Myself, Nice Knowing You All...
Cam
Nz Petrolhead
Whangarei, New Zealand
I thought of that after i posted... 3 times more difficult now....
Pitted cams, i reckon that would sound pretty cool... got any pics?
robbie
Osceola, Missouri
In the 1980s when I was in high school my brother had a 1972 Volvo station wagon that had twin carburetors with piston throttle. Looking back on it I understand that they were probably super cool and we should have rebuilt them, but we didn't feel like messing with it at the time. You couldn't get inexpensive parts on the internet back then, and the nearest Volvo dealer was a 5 hour drive away. Most folks didn't even want to make a long distance phone call in those days. We assumed that these carburetors wore more trouble than they were worth.
So we built an adapter out of a short piece of exhaust pipe with a sheet metal flange on each end for mounting. We attached a Subaru carburetor to one end and bolted the other end onto the manifold. That left one extra hole in the manifold where the other carburetor had been. We bolted a plate of metal over it.
The car ran so well I had to wonder why they didn't send them out from the factory with Subaru carburetors. If you have to, you could do something similar to your Honda engine.
:iagree:
Great Idea Robbie, you beat me to it. Toystory could build his own DIY intake manifold and install a relatively inexpensive smaller automotive type carb and air cleaner.
It would be just be like building an upward type header, (like tractor pullers use) except you'd simply have the carb bolted on at the collector. You can buy all kinds of different angle/diameter (build your own) header tubing bends and components to just weld together like assembling tinker-toys and build a really cool looking intake for any application.
Kinda like this pic, but just with much shorter runner-tube and collector lengths:
You'd just have to get the jetting dialed in, and if the carb was too large of cfm you could just simply limit the max-butterfly opening position to compensate. You could even mount a smaller sized freakin Holley 4 barrel on there if you really wanted... That would look cool as hell !!!
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
I think they're Keihins. Same difference, apples and apples.
Toystory, have you tried your friendly neighborhood Honda dealership? Last time I needed parts for my bike I walked in there and ordered them over the counter with no problems. Honda is one of the more supportive manufacturers for their older bikes, even if they don't manufacture parts they still have years worth of old stock in their warehouses around the country. KTM is probably the worst, don't ever buy a KTM older than 1994 because you will not be able to get parts, period.
In no particular order-
I havent tried a Honda dealer yet, but I've been sandbagging a few related forums and I'm not liking what I'm reading so far. Seems like these things are a bear to lay hands on. I can't understand why there isn't an obvious aftermarket manufacturer. I'll have to dig a bit deeper.
I did think of alternate solutions, including the single carb on manifold idea. I may be able to pull it off, but haven't the foggiest idea what I'd be looking for in a carb. I'd definitely need some help on that! I wouldn't know where to begin.
Rustydog2010
NZ Nutta :|
New Zealand
Before I found carbs for my 750, I was planning on using a carb of a twin carb 1500cc honda civic. 1500/2=750. In theory this should work, just block of the balancing pipe and some others, you'll be good to go. :thumbsup:
Jeremy.
I found an online carb calculator, suggesting I needed about 140 CFM. Unfortunately, a lot of the smaller carbs aren't "advertised by CFM, just the bore size, so I'm left guessing.
I also know that there's more to it than the displacement. The volume requirement involves max RPM, too- so a carb off a similarly sized but slower running engine won't do it either. Or at least not from what I understand.
My solution certainly wouldnt be a good as perfectly matching the carb to the engine, but it would work and allow you to use most any automotive carb you you might already own or found at a great price.
If the automotive carb was too large (and most would be) you could easily tell where your throttle-opening limiter should be adjusted to. While riding and pushing your gas pedal down you would eventually reach a point where you you lost power and rpm. You'd simply adjust your throttle opening limiter to just before that point.
It'd be best to design/install the throttle limiter so you could easily reach and adjust it while driving...
All you have to do to make any carb a smaller cfm is simply not allow its throttle-shaft to fully open!
You'd probably have to solder up the orifice in your main jets and then re-drill them to a much smaller bore, and then slowly enlarge them as necessary until your spark plug readings showed a correct mixture.
Your carbs air-idle adjustment screws could simply be adjusted in much further than the cars engine would of needed to help compensate for your smaller engine too.
Here's a link to some on-line header building parts suppliers to check the pricing of building your intake: http://www.google.com/search?source...=1T4GZAZ_enUS369US369&q=header+building+parts
Your manifolds runner tube ID's. should be similar or just a bit smaller than the intake ports of your head. You'd have to build your own intake mounting flange and carb mount adaptor.
Badot
Not sure how much this will help, but just throwing it out there:
To get the needed CFM for a carb, take the displacement and convert it to cubic feet (750cc -> .02649 ft^3) and then multiply it by half of the max RPM (.02649*5000 = 132.45)... you multiply it by half the max RPM because it draws in air once per 2 revs.
Since this is a flow rate, the driving force behind the carb (Bernoulli's principal?) should be maintained... at least theoretically. I'm not sure how easy it would be to take the effect of the pulsing of air via intake stroke into account though, nor how much it would affect anything...
At the very least though, this would probably be a good place to start, as far as if you're looking to pull carbs off of cars or other bikes.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
I like where this is going! I never would have thought to use an automotive carburetor, as it would entail building a sheet metal intake. How are you at welding aluminum, toystory?
Any 2 barrel carburetor from any late 70's to mid 80's vintage japanese cars should work. Look for something with small displacement, less than 2 liters. My old 1986 dodge charger 2.2 had a 2 barrel Holley 5220 rated at 280 cfm, which is too large but gives you an idea of carburetor sizing for passenger car engines. Something smaller and more gutless will no doubt have the perfect carb for your needs :D You just need to build the manifold!
I agree that'd be cool, but I think it would be a whole lot easier/more-realistic to build the intake from various (build your own header) steel-tubing bends and a header collector like I'd already suggested.
It'd be like... totally tubular dude ;)
I like the zoomie/header style intake idea, and with the existing intake port locations would probably be most workable.
I am inequipped (and entirely inexperienced) to weld aluminum. Pity- I'd love to learn.
Searching my brains out on the 'net last night, I found a guy on FleaBay selling new aftermarket diaphragms. Normally, they would be sold as part of the slide, but this guy's selling the rubber only. A bit pricey, I guess because he's got the market by the short 'n' curlies.
I'm going to do some more homework before making any decisions on it though...
Thanks for your input fellas, keep it coming!
