I May Kill Myself, Nice Knowing You All...
anderkart
Surprise Arizona USA
Just my 2-cents:
A big-ol engine like that would definitely be cool in a heavy off road kart kart, but I think I'd be kinda tempted to just get the bike running and sell it off to buy a nice 250/500cc dirt bike engine for the kart build instead.
You'd still have wicked acceleration and speed but the kart could be built to end up much lighter/shorter so it would most-likely handle/turn better.
I'm thinking the lighter more nimble kart could actually end up being faster than the heavy/big-engine kart in many typical off roading type situations. It probably wouldnt get stuck in the mud, sand and stuff as easy too.
HellSpawn
Wadena, Minnesota
Just my 2-cents:
Totally agreed, I also don't think that bike is in all that bad of shape anyway, personally I'd restore the bike, but then again I am more of a bike person tbh.
I do see your points, and somewhat agree. I did have such a thought. A restore would take some money, which I don't think I'm willing to do. Got too much else to pay for right now. Simply getting it running and flipping it for a few bux might be an option, but- as I'm aiming for a UTV type of thing, I'm not necessarily looking for the light, nimble stuff. An attractive feature of the street bike engine is the charging system which I know a lot of dirt bikes don't have. I want lighting, and I've got a cool little 1500lb winch to go on it.
At any rate, it is a long term build. If the plans change (again!), then they change. Is anything ever really written in stone?
Oh, this poor, poor girl... Nearest I can figure, the fuel's been sitting there for 5 years or more. It's totally turned to schmutz. The throttle's frozen, the choke, and 3 outta 4 slides won't budge at all!!!
I just got the carbs out of the bike. Now I'm trying to figure out how to get those slides out without forcing them, I certainly don't want to cause any damage. They are plastic- will massive quantities of carb cleaner hurt them? I'm none too familiar with this type of carb.
Okay- So I stopped by an auto parts store on my lunch break yesterday and picked up a gallon of carb cleaner. Next few days I'll take a what at it.
Please read my above post, I'm paranoid I'm gonna kill the slides!!!
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
The slides are made of nylon, which absorbs water over time and swells up, sticking the slides. Oil won't hurt them, but some solvents will, namely acetone and MEK. You should be able to free them up with some motor oil, 2 stroke oil or penetrating lube like PB blaster, WD 40 or Liquid Wrench. If you can, take the diaphragms off before you start saucing up the carbs, carb cleaner can eat them. If you still can't get the slides out, try heating the slide bore area of the carb with a heat gun, propane torch or even a hair dryer. Apply gentle upward pressure on the slide while heating, and remove the heat as soon as the slide is free.
Thanks for the insight. I used a ton of WD40, and carefully wangled them out. Oh man, there's a ton of spoo on them!!! I REALLY have my work cut out for me here...
The bad news? One diaphragm is torn, and a couple are less than brilliantly flexible- so I guess I get to start hunting for rplacements.
The bad news? One diaphragm is torn, and a couple are less than brilliantly flexible- so I guess I get to start hunting for replacements.
EDIT- BTW, the slides appear to be aluminum.
anderkart
Bummer the diaphragm tore, I was going to suggest soaking the whole assembled carbs in a bucket of gas for a few days before even attempting to disassemble. I've had good luck bringing old funky carbs back to life w/o having to buy a kit that way. It seems to kinda re-hydrate dry-brittle gaskets/accelerator pump diaphragms before they have to go through the stress of disassembly.
I peeled the diaphragms out ultra carefully- I think it was already torn. Looks like I'm going to have a bear of a time finding a replacement. I was pretty angry last night when I discovered it- then I reminded myself that it IS a 28 year old bit of rubber. What do I expect?
Yeah- I've started looking, and I can see it's going to be an uphill battle. Spotted a coupla used ones on FleaBay- Problem is, of all the things I'm willing to purchase used, a 28-year-old piece of rubber's no high on the list. I hope like heck somebody's making them in the aftermarket somewhere...
Cam
Nz Petrolhead
Whangarei, New Zealand
Probabley a mikuni carb? see if any other jap bikes had the model of carb, or similar, or you could adapt a newer carb to suit i guess.
Those rubber boots between the air box and the carb are a real bugger when they go hard, good luck dude!
