comet 40 series t.c.
geppsr
moneta Va.
howdy new man here. came across this site while looking for info on comet tourque coverters, and i know for a fact these forums are a wealth of knowledge. i am running a 40 series t.c. off a tecumseh 8hp. vertical engine hooked up to peerless 3 speed mower tranny. centers on shafts measure 11 1/4in. cannot change this measurement. using an 11 1/2 in belt now. when i try to mve in 1st gear, lower half of driven pulley turns, but not the top half. any help greatly appreciated. gepp
geppsr
moneta Va.
here are some pics i hope
For starters, the OC measurements have to be pretty bang on. It seems you're 1/4" out- making the belt too loose. See what you can do to move the centers further apart, like by slottong the motor mount holes.
EDIT- I just re-read that. You've obviously got bigger problems, as the entire driven unit should spin as one. Take it off and find out why they are not locked together. THEN alter the spacing.
Now THAT is COOL! Did you scratchbuild the whole thing?
Okay- we need build data! Pics, specs, parts used- the whole shebang! How very unique!
r_chez_08
Should be in the shop...
Cornwall, UK
I agree, that is one cool project. More pics!
I think the plastic buttons can break on these, but dont know if that would causeyour problem. Do you think you can post more close up pics of the tc?
Rob
Edit: im guessing thats a mower engine?
wall gator
TAMPA BAY AREA
Rob
yes the buttons do break/ware out........imo....need to check the spring/broken/not in one of the 3 holes/wore out???? if spring is o.k./change out the buttons......if still having problems,,, let us know........very nice ride!!!
geppsr
moneta Va.
40 series t.c.
where are these buttons you refer to? i have looked on the spec sheet i gtot with it, but cannot find them .Thanks Gepp
geppsr
moneta Va.
thanks chez, i found my problem. i was reluctant to take the pulley apart because i read where some one had problems after doing so, so i threw caution to the wind and pulled it apart only to find out the little key was missing. have no idea how it came ouff the shaft, so im back running again. want to thank all who responded to my problem. if i can be off any further help as to some one wanting to make a build, please dont hesitate to write. gepp
