I May Kill Myself, Nice Knowing You All...
I was talking to a buddy of mine about a future build offroad kart I've been planning for a while. I suggested that I was looking for a liquid cooled bike engine with a few more ponies than the one I had originally planned on using.
He offered me a COMPLETE 1983 Honda VF750F Interceptor for $50.00. Needs carb work. Factory spec is 86HP@10k.
Should I get it? Ha! Right, like I'm gonna NOT get it!
I've made some good friends here, it's been nice knowing you all...
:surrender:
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Dude those Interceptors are nice bikes! I should know, I ride a 1982 V45 Sabre (same engine as the VF750F, except no fairings and shaft drive instead of chain). It's the musical sound of the V4 that gets me, the stock mufflers rotted out so I replaced them with a pair of emgo shorties. Now it sounds like a small block chevy when I romp on it! They were a technological showcase at the time, a testament to Honda's engineering prowess.
One thing to watch for with the V45's is the condition of the cams. Honda had problems in the first couple years of production (1982-83) with camshaft lobes pitting and eroding. This is partly caused by manufacturing defects and partly due to the fact that the top end is last in line for lubrication. The lube system is priority main, meaning the main bearings and bottom end get fresh filtered oil first, and the top end is basically splash lubed with the leftovers. Excessively high operating temps exacerbate & accelerate the problem, if the bike was used as a stop & go commuter it may well have pitted cams.
What this means for you is that you'll want to pop the rocker boxes off and have a look at the cam lobes, if you see pits then it's time to start hunting for some cams on eBay. Otherwise, keep good oil in it, keep it nice 'n cool and like most Honda products it will serve you well for years to come :D
Otherwise, it sounds like you have an awesome project ahead of you :thumbsup: I'm looking forward to the build thread!
Mech- thanks for the thought-food- Now that you mention it, I seem to remember my buddy telling me of a top end oiling issue when he bought the bike, a good 10 years or so ago. Can't remember if the engine was modded to address this, but I do seem to remember him telling me a mod was available. I'll have to do some more homework on the subject, and press him for details when I get the bike.
My preliminary research seemed to suggest that when the interceptor came out, it was the be-all and end-all for sportbikes. I'm more of a cruiser guy myself. A few years after he got the Interceptor, he picked up an '84 Shadow 750- Now THAT bike, I fell in love with. I'd borrow it to got get milk and not come back for three hours! IIRC, you could get the Interceptor engine in a Shadow, called the Magna, but the twin was lovely.
Anyhow, the build was going in stops and starts, and I think I'm going to have to rework the plans a wee bit. Originally, it was to be powered with a Virago 250 I scored cheap, but I keep leaning towards putting the 250 in my current kart, in favour of something more powerful in the new project.
The new project is really turning into a UTV. Sit in, full suspension, cargo rack, trailer hitch. Biggest issue is that I really want reverse. I have to start looking around in hopes that I can find an FNR gearbox capable of that kind of power...
Only as a desperate measure- If things proceed as planned, I will need to make fairly heavy use of reverse and would prefer to use the engine's power for this.
Rustydog2010
NZ Nutta :|
New Zealand
Be sure to tell your wife I got dibs on your guitars before you take that first ride ;)
I'll take the kart, so it can be my turn. ;)
In all seriousness what kind of buggy is it going to be? A home built contraption? Or to some plans? By the way you are talking, i'm guessing its going to be geared pretty low?
Jeremy.
Well, I'll have to dig up some info to step you thru the first plans or two, but the short answer is homebrew. I wish I had the budget and tools for something uber-cool like a piranha or sidewinder, but that's not likely to happen. I've got an oddball frame I've been fooling with, but the new engine option may take me right back to the drawing board. After I get some more info/pics together, I'll let you know.
Meanwhile, I'm still doing research on the engine. I stopped by to have a quickie look on the way home. I'd forgotten about the horrible black paint job the owner had done some years ago.
Anyhow, the throttle's seized up, and so are the carb plungers (3 out of 4, anyway), so I've certainly got my work cut out for me. I'm hoping to save the carbs and get the engine running in the chassis before proceeding with removal.
Here's a couple pics- Dust, crappy overspray, oil and grease, and all!!!
Wow, that's gonna awesome. Kinda looks like the V-design has some serious length, more than a big in-line 4. They got that front jug angled almost like a Vincent black shadow.
Yeah, it's a 90* v-bank. I measured approx 24" from the top of the (forward) rocker cover to just past the output sprocket. It's a freaking monster. Two rads on this bike!
I'm actually toying with a transverse-mounting concept.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Looks good man! I can't tell if its got the factory connectors on the voltage regulator (the little finned heatsink lookin' thing on the left side of the bike, just below the seat) but you might wanna check them for heat damage. All Hondas of that era have 3-phase AC charging systems (voltage output can be as high as 600 VAC at full throttle!) which tends to cook both the stator and the voltage regulator, as well as the connector between the two. That muffler is nice too! Carbon fiber, swanky :thumbsup:
If you mount it transversely, how would you power the wheels?
Thank for the tips, Mech!
The mental gears are turning re: transverse mounting. One option I do have is an RAGB from an old lawn tractor's snowblower attachment. A solid piece it is, all iron and weighs a good 10lbs or so.
Perhaps I can source a suitable diff to use.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
The mental gears are turning re: transverse mounting... Perhaps I can source a suitable diff to use.
What about using a 4x4 transfer case and building a 4 wheel drive buggy? Then you'd have no choice but to mount the engine transversely to drive the transfer case. You'd probably end up with something similar to this:
The Rhino RTV, built by ROI back in 2007ish, used a Honda Civic drivetrain (complete with transaxle) mounted longitudinally, each CV axle driving a differential. The first single passenger model had the driver sitting beside the engine, later models (like the one in the pic) situated the engine behind the driver to create a narrower vehicle profile. I saw it on that stupid Trucks show on SpikeTV one saturday morning, the thing was climbing a vertical wall with the front wheels! Anyhoo, food for thought...
What about using a 4x4 transfer case and building a 4 wheel drive buggy? Then you'd have no choice but to mount the engine transversely to drive the transfer case. .
I'm familiar with the concept (and that buggy) and have thought about such things in the past- But honestly, I don't want something that big. And- If I did, I'd make use of an existing engine/tranny combo from a front-wheel-drive POS civic or something. Somthing like this is too large and heavy for my purposes. Ultimately, I think I'm going to end up with something that resembles a Gator, or similar UTV.
I would LOVE 4wd, but quads and parts are a tough and pricey find around here... I AM batting around the idea of tandem rear axles, both driven, to result in a 4wd, 6-wheeled vehicle.
Not really a go kart per se, not really a buggy either. A DIY UTV, I suppose.
Yes, I realize that tandem live rear axles will result that something that steers like an oceangoing freighter. I have a couple possible solutions for this.
EDIT- bad news/good news. I just spoke to the bike's owner and it appears we go our wires crossed the other night. Turns out he wanted $50 for the engine... Naturally, I want the whole thing for brakes, controls, exhaust, gauges, etc. The good news is he agreed to $75 for the whole shebang. Cool. The way he was talking for a minute or two, I was starting to think he had been kidding about the $50 and was going to want a few hundred. Phew!
