engine clutch mounting plate?
amcjavelin
amcjavelin
western maine
ok i today i received my clutch kit its TAV2 30 rated for the 8hp engines well its too small i goofed, my ? is can i mount the plate and buy the tc 40 driven clutch and use the 5/8" jackshaft and still use the 10 tooth set up?
So your basically just asking if a tav-2 mounting plate and jackshaft would work with 40-series driver/driven components right?
If so, I dont know the answer for sure. I dont remember seeing anyone do that but I dont think comet ever sold a kit that way. So its very possible that plate wouldnt be strong enough for your 16hp engine, especially factoring in your considerable weight, and desire to use it for serious hill climbing.
I know comet had problems with guys bending/breaking the older original style tav-2 plates (w/6.5hp...) and redesigned them to be stronger.
Plus you'd need to double check that a 40-series belt was available in that length you'd need here. Considering everything, I think you'd have a much stronger setup installing a conventional frame mounted jackshaft when using 40-series components.
If Blaz doesn't find your thread here and chime in, I suggest you contact him to get his opinion before trying this, here's his contact info: http://www.diygokarts.com/vb/member.php?u=5853
Are you asking if a TAV2 Drive or driven can be used with a 40 drive or driven? No. Not unless there's a big secret I don't know of. Isn't the TAV2 an asymmetrical unit? Check the profile of the belt- Is it angled on one side and nearly flat on the other? I think it is... The Comet 40 uses a symmetrical belt, same angle on both sides... No dice.
amcjavelin
amcjavelin
western maine
i was afraid of that i was going to get a seperate plate and get a tc 40 drive and driven but people are telling me the plate is not stong enough for 16hp engine?
amcjavelin
amcjavelin
western maine
i did not n=know that dam, i think i should of stuck to my original plan tore out the three wheeler engine i had and put that in and jack shaft i knowthis probably a joke but what about a 125cc motorcycle engine with built in 4spd? semi auto?
Blazkowiez
Kart Aficionado
Houston, Texas
Hey, if I understand this correctly you want to buy a series 40 torque converter and use your existing series 30 mounting plate. This may not be the best idea for an 8hp engine.
First of all, if you have an 8hp engine and an existing driven clutch consider a 1" bore drive clutch for your larger engine, its affordable considering your set-up and the easiest option.
Next, series 40 is for larger horsepower and torque, typically the driven clutch requires an outrigger bearing so it won't snap the mount. They did make 5/8" bore driven series 40 clutches but that doesn't mean you can put it on the weaker mount. I'm not certain it'll break anything but I wouldn't trust it, plus you have to keep in mind that the series 40 driven is a wider clutch in general, without changing out the jack-shaft you might not be able to fit the clutch and a nut on the threaded shaft.
I hope that helps.
amcjavelin
amcjavelin
western maine
yeah i just my 16hp clone today and its huge i hope i have enough room well i guess i'm going 40 series clutching and seperate jackshaft
amcjavelin
amcjavelin
western maine
oh i can but what a act of congress, the guy wanted me to send a ebay emails that ive tossed out to verify different whatever it is, then there was someting else to and just said to heck with it i'll sell it out right
Hey I know you got a 40-series ordered for your 16hp engine and thats the best way to go,
but I was just kinda wondering if you've got the exact same 1" bore tav-2 model as shown
here on this page? --> http://gtcmanufacturing.com/
They're claiming this 1" tav-2 model is rated to 13hp... not 7hp like their 3/4" model.
I'd never noticed that before, maybe it woulda held up on your minibike with the right gearing.
Ok, I just checked out the pics in your for sale ad, You've got a genuine Comet tav-2, not a GTC brand. So I guess the original Comet tav-2 was rated at 8hp max in both the 3/4" and 1" bore versions.
And then only the GTC brand copies have a higher 13hp rating on their 1" bore tav-2 model. Mmm... that's kinda strange, I though CTC just copied the Comet designs, but those max power ratings seem to suggest otherwise.
no, i'll do it right the first time around i hope just got get a driven and jack shaft kit
I totally agree with you, I just found the different specs interesting between Comet and GTC tav-2/1" bore systems and basically wanted to find out more info on this matter and confirm which brand you had for sale.
You should probably edit/mention/play-up your tav-2 is a genuine Comet brand in your ad's info. Lots of guys here trust the Comet brand a lot more...
