tec 6hp mods
ed1380
Banned
ATL, GA
heres the rear suspension. the rear hub is made out of angle iron. that should cut down on the cost of having custom made parts.
A arms have been remodeled to .6" down from 1"
AutoMX
make sure you get some bushings to cushion the A arms, whether you buy em or make em out of whatever rubber/hose you can find. its gonna make your ride better, prevent the metal from rubbing, and keep everything from shattering if you hit bumps.
is this gonna be a street kart or an offroad one? one or the other will affect ur engine shopping alot, the offroad type (atv and dirtbike) will offer more torque but shake ALOT at high rpms. the street type motors will offer less torque low down but higher top end.
also if youre gonna go out and spend the money on an ATV, at least use the suspension from it too. poorly made A-arms will break the first time out and then you're stuck and back to square 1. what kind of metal are you using? what thickness round tube? etc..
lots to think about..
gocartkid
Bad Attitude
CT
SWEET! COOL! AWESOME!
Totally off topic but - How do you cut metal?
I'm not sure who you are addressing, but I cut with various grinders, saws, a cutoff wheel, and I grind some metal with my bench grinder.
I too think that you should just use the atv rear suspension, much cheaper/easier and you'll be happier in the long run.
ed1380
Banned
ATL, GA
off road but not really rough terrain. as for the engine. beggers cant be choosers. im going with whatever i find cheapest.
metal is going to be whatever i can find/salvage.
ed1380
Banned
ATL, GA
i have a sprocket laying around. heres a pic. what kind of hub do i need for it? also distance between teath is 5/8 what size chain is that? width inside of chain is 5/16
sorry for the crappy pic. was too lazy to get the camera
ed1380
Banned
ATL, GA
where can i find that sprocket?
i google forever and couldnt find what size chain it needs. i know its a 50/500 series but width is different. any pointers?
i have 5 ft of it but i need a connecting link
ed1380
Banned
ATL, GA
heres some more pics. this is pretty much as much as i can do without actually having any parts
ed1380
Banned
ATL, GA
thanks.
front tires are there just to be there. i still havent decided what tires im using.
im having problems finding hubs for the rotor and sprocket
jr dragster T
Cold place
5ft of chain duh
just found out its a 525 chain
i said everything in post #47
Be easy on the guy hes the one helping you! And plus you NEVER said it was 525 chain when you asked, All you said was a 5/8 gap between links. If you want help first find out the pitch then ask!
ed1380
Banned
ATL, GA
5/8 between the links is the pitch.
i dont like corresponding. people dont know your tone of voice. that post was made in a sarcastic tone.
cmon what else can you have 5ft of and need a connecting link :roflol:
ed1380
Banned
ATL, GA
In MX, the front tire is 2 inches bigger than the rear, easier for turning, the same goes with the width as well.
are you serious? all the buggys ive seen have narrow front tires and almost paddle rear tires.
mx is motorcycles right?
oscaryu1
Actually, when I said "5ft of what?" I meant what pitch, which is why I typed what I typed after that question. :)
