18hp Briggs
element10554
Glen Mills Pa
Ok so I am in the process of restoring an 18hp Briggs and Stratton
Model 422437
Type 0749 01
Code 87010512
I have wire wheeled the air filter and took off the rust and I have spray painted the air filter as to help it stop from rusting again. I did an oil change and put in new spark plugs.
Now I need to find a manual for this engine so I can properly take apart the carburetor and clean it and set up the electric starter. Ive tried to plug the numbers into google but have come up shorthanded. Also after The carb is cleaned and the starter is set up any recommendations on what I should do to the engine to prep it to be started for the first time in almost 2 years?
NEW QUESTION
I need wiring help. I can provide pictures if the video does not have enough detail.
http://www.youtube.com/watch?v=556FYIu9Ln4
Please bear with me I am no artist and I suck at microsoft paint. Please try and use these as a reference to the video.
Pictures
This is the rust in the intake I am talking about.
This is where the engine will end up.
element10554
Glen Mills Pa
Going to avoid making a new thread. When I took off the carb the intake pipe leading to both cylinders had rust inside is there anything I can do to clean this? Its not really to bad. Its mostly just discolored with some grit to it.
element10554
Glen Mills Pa
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
hey man thanks thats just what I wanted. The only thing is when I open the manual it says for model 422400 does that mean it also extends to my model 422437? I looked at the pictures and they look EXACTLY like my engine. And last question is whats with the E1 and E2 at the end of the model number?
Briggs arent my area of expertise, but I assume the just condensed the 2 into 1.
For future reference, B&S had all the manuals for free. Just search on their site.
Bluethunder3320
how about electrolysis rust removal?
do you have some metal rod (or any piece of metal) wire (or jumper cables) and a 12v battery?
element10554
Glen Mills Pa
Run it with rusted pipes "as is".
Will not hurt anything. Could use a bottle brush.
Thats exactly what my brother said ( works at a small engine repair shop) he said as I use it the rust will eventually go away. I just was not sure if it would hurt anything at all or if there was a way to clean it out. Id rather have a clean pipe even if it doesnt affect the performance. Now if I use a bottle brush and get some of the rust loose can I wash it out the debris in anyway? I assume that if you have an air filter to stop dirt from going into the engine then rust debris can not be to good for the cylinders.
element10554
Glen Mills Pa
Rust will simply disintegrate and blow through.
If really concerned...an old trick is to throw in some small stones and shake around.
Rinse out with any petroleum base product.
Thanks. Like I said its still attached to the engine so it would be pretty **** hard to shake it around I will just grab a wire tube brush and run it through a bit. Thanks again for the info
