fold up shovel
fowler
Bullsbrook West Aus
on redsoxs request ill post my fold up shovel pics and do the best to explain the build process
this is quite differant to most designs as in is not designed to take on your bike or put in your back pack to go hiking
it is a shovel for off road users (or buggys;))
Tools (min)
welder
drill
pliers
hack saw
bastard file
Tools (max)
oxy
plastic dip
chop saw
grinder with cutting disc
english wheel
#1
draw blade on template and get correct size
cut blade out of 2mm steel plate
roll to appropreate diamiter
(or go to hardware store and buy blade)
#2
get angle iron 22mm x 22mm x 3mm
cut two peices 110mm long
drill an 8mm hole 45mm from one end and 1mm down
drill a 10mm hole 20mm from long end
cut a staight line down to each side of the hole as to make a slot
#3
get 100mm of 25mm of box tube
drill 8 mm hole in one end
find suitable 8mm bolt and bolt the two peices of angle to the box
lay it on a table so the far end of the box is in line with the slots
mark out where the corosponding slot must go in the box tube
drill 10mm hole on mark and anoughter 10mm hole 40mm away and cut out middle section
#4
get 500mm peice of 27mm x 2mm round tube
weld it to the box tube so the end with the slot is closest to the joint
#5
rebolt the angle iron to the box tube
put a 10mm bolt in the slot so it holds the angle rigid against the box tube
weld the angle iron to the blade in a way that ensures the 8mm bolt is about 20mm in from the edge
#6
get peice of round tube that fits nicely over the first bit of tube (i found some 29mm inside dia)
drill two 6mm holes 40mm apart at one end
find two 6mm nuts and weld them over the hole in a way that lets the corosponding bolt pass thru into the tube
weld a little peice of bar over the top of the bolts to make a handle
weld a cap over the far end of the tube
#7
get a spring with a key ring at each end and put it into the box tube so on end is on the 10mm bolt and the other on the 8mm bolt. the 10mm bolt will slide back and forth in the slot and will lock into the slot in the angle
slide the big tube over the little one and do the bolts up at a desired handle length
:wai:
we have used the shovel many times down at the beach
and it works really well
we got our toyota landcruised bloggged to the chassie and dug it out in 30mins (alought the rising tide was a good insperation)
it sounds abit up my self but iv seen it on other forums and it looks like a good idea
im happy for anyone to make it at home
but u cant make int on a large scale
and remeber i was the first bastart to build one:thumbsup:
redsox985
PA
I like the idea. I'm shooting for a smaller, backpack sized one. I have an idea. Here's some photos of the one I built that was a failure.
redsox985
PA
So just a scratchy drawing on any random scrap? I get it. I'm going to draw up plans for my new shovel soon.
redsox985
PA
Ok, so I just threw together some "back of a fag packet" drawings for the shovel I hope to build. They might be a bit more detailed. All measurements are in inches, the spade is 1/8" quench hardened steel. Fire up the forge! The handle is kind of a crap shoot. I looked at a backpacking shovel I had and it was 7/8" tube with some pretty intricate crush points and bends. The shaft of the shovel is threaded to accept a 1" nut. TPI unknown. 12 or 14 are the two options for 1" SAE threads, IIRC. The spade mounts are 1" angle iron cut 1" long. Any shaded areas are to be removed, I'll probably mill them out.
redsox985
PA
How about you buy me that one for $77.90 and pay the $30 to have it shipped to me. Talk about a rip off!
Try here. The green tri-folder is identical to the one I picked up at Dick's Sports a few years back for $10 before I went camping.
glb7
close to Portland, Oregon
bighead
Pacific Northwest USA
I need to make 4 of them. So $100 on shovels is to much. Plus some of the cheap ones are worthless. If I have to put out a fire that I started. I would want a solid shovel.
You live in Oregon? Did yoiu know if you ride your kart of road you need a shovel? No shovel during fire season? you will get a ticket. That means I need 6 shovels by next summer.
redsox985
PA
Pick up the $10 ones at a sporting goods store. They look identical to the American ones posted above and are pretty rugged. They're all steel 3 piece folders, from what I've seen.
sexyvicta
yeh army surplus. I have one. They also have a saw blade on one side of the shovel so you can chop wood
