live axle vs. dual swing arms
keep33
Grand Rapids, MI
Hey, all. I'm in the tear-down process of my 480 Phazer motor mount onto my Tomberlin crossfire 150R, and have been wondering if it is worth trying to create a chain-drive spool and swing arms and run IRS, or just stick with the single swing arm and live axle on it now. Simplicity and expense are always a hurdle, but I want to make the best kart I can. What do you think? Is it worth it, or should I modify the existing swing arm and live with it?
redsox985
PA
Well, IRS will be very nice, but will also be a lot more work and cost. How has it done so far with the swing arm? Are you satisfied with it?
keep33
Grand Rapids, MI
I have only driven the kart with the original 150cc engine mounted to the swing arm... Not the greatest ride. Lots of unsprung weight. Either way I plan on mounting the motor to the cockpit and having the swing arm free from bearing the motor's weight. Some money and time is acceptable. I just don't want to have to borrow money (joking) to complete it.
Since both options will have the same basic starting point, why not go ahead with the single, dependent system, and if you're not thrilled with it change it later?
redsox985
PA
When I almost bought a Crossfire, I was researching and found the stock shocks are poo. They are incredibly hard and should be replaced. I would try the swing arm mount for simplicity of chain tension with some good shocks in there.
keep33
Grand Rapids, MI
All food for thought. I'm not sure which way I will go. Just bought a camera to start pics, though. Hopefully I can figure it out. Im a lot better with steel than I am with electronic technology.
redsox985
PA
Actually, either isn't good. Too hard and every bump hurts. Too soft and it's like there's nothing there!
