Would it be possible to mount an engine on the left side?
e85
The great NW
Being as the crank spins counter clockwise, this in theory dosent seem possible. But I thought id ask anyways
redsox985
PA
Couldn't you use two jackshafts so the motor goes into JS1 then out via a cog and a cog into JS2 then a chain out to the sprocket? If you had a CW engine or needed to relocate the PTO, I think this could work.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Someone on heres done that.
Would it be possible to mount an engine on the left side? Being as the crank spins counter clockwise, this in theory dosent seem possible. But I thought id ask anyways
I'm confused, left side of what? This is the Mini Bikes an Choppers forum.
Are you asking about installing an engine backwards in a mini bike (with the pto on the right), or do you just mean an engine on the left side of a go kart or maybe a motorised bicycle?
redsox985
PA
It would work...but would you want to? Nothing to be gained except some unnecessary complexity and added weight.
Oh, I agree entirely, but I was just proposing a solution for the sake of argument.
r97
Measure twice cut once
Massachusetts, USA
i used a js to re-locate the chain. worked out ok, but i would avoid it if possible. can you better explain what you want to do?
shaggy0001
enthusiast
australia
Ok a little off topic but while rebuilding my victa engine i wondered what would happern if i rotated the head 190 degrees so that the exhaust and inlet ports were on the other side of the motor :idea2:
just for the sake off argument
sideways
Unfinished projects king.
Perth, Western Australia
You can turn the barrel 180* on a Victa with no problems, make sure you put the head on the same way so the ignition lead will still reach though.
Useless fact: On Victas industrial engines, you could order them with the barrel turned around 180*.
I've got one I turned the barrel around on, works well.
Thanks
Hayden
shaggy0001
enthusiast
australia
Thanks
Hayden
Thanks that's great to know, will have to give it a go when I start building my kart
