can you mount a tc horizonal on a hf 6.5 engine
metalthrashinman
Hope, NJ
Horizontal is fine. Why do you think that it would not work horizontally?
Unless you are asking if the plate will mount horizontally, in which case; you can make it fit if it won't. I did.
kartingizm
Murray Hardrive Gokart
does any one know how long the tc is? from the driver to the driven??? thanks guys
redsox985
PA
I have mine horizontal with the driven towards the front of the kart and have ZERO complaints about it. The kart I bought it from had the motor up higher and the TC vertically mounted downward above the sprocket. As long as the backplate bearings don't hit the block, it will work any direction.
