All I'm saying is that if everything else fails, crack back into it, and make sure the lifters, pushrods, rockers, and valves are as they should be. Maybe double-check the camshaft alignment again...
no i did not make my own gaskets, the engine has less than 10 minutes of run time on it.
no air filter mod just exhaust at this time, and there is a briggs muffler on it.
the jet is stock. i bought it from robertskartshop.com because i drilled out the old one too much.
also dont think the jet is too small because my friend has a straight pipe and no governor in his and it runs fine with everything else stock.
i decided to put the governor back in because 30mph is fast enough for me... lol
Well, you could... But it won't solve this problem!
oh... i thought removing the rod and crank was the only way.
anyways i got the governor back in, and now i have to put everything back together. tomorrow tho its time for bed.
devino- ill try making a gasket from a thin cardboard box... bcause i cant wait for shipping right now.... lol.
if it still has this problem ill order a gasket... well maybe ill order one tomorrow since they are cheap.
One more thing, that little kill switch you've got. Move it. If everything comes to a stop very suddenly it's going to rip you nuts out.
Just saying.
Thanks
Hayden
Wot he said, seriously do it! Unless you want to see what your gametes look like in their natural habitat.
Gaskets: I assume you ran it and sprayed some WD40 (or similar) around the gasket (not carb intake) to see if the revs change? If they do you've got an air leak.
Allrighty, then! So now what? All over again?
