pretty bad clone problems
All I'm saying is that if everything else fails, crack back into it, and make sure the lifters, pushrods, rockers, and valves are as they should be. Maybe double-check the camshaft alignment again...
slideways
Well first of all never use a flathead plug in an OHV engine. They are long for a reason.
You said you made your own gaskets? Did you take any pics of that? You have to make sure the new gaskets match the old ones and they go in correctly. There is a right and wrong way. They can block the air mixture hole if you didn't make them right or installed them backwards and makes the motor run like crap.
How big of a main jet do you have in it?
I'm assuming you have an intake/exhaust from the pics. Did you drill the low speed jet?
You can get kickback from unburned fuel mixture igniting at the wrong time due to an incorrect plug... which may explain why you don't have that issue now.
Do you now how to check valve clearance? If its been touched inside it is possibly something got out of wack just a hair but it sounds more like a carb/ignition issue.
Bluethunder3320
no i did not make my own gaskets, the engine has less than 10 minutes of run time on it.
no air filter mod just exhaust at this time, and there is a briggs muffler on it.
the jet is stock. i bought it from robertskartshop.com because i drilled out the old one too much.
also dont think the jet is too small because my friend has a straight pipe and no governor in his and it runs fine with everything else stock.
saebajacaptain
Muddigger
Chicago, Originally from Carsonville, MI
sounds to me like a timing problem, but if everything is correct, it could be a/f mixture, replace plug, experiment with starter fluid/flammable brake cleaner and tell us what the end results are, if it will still run like this when hitting it with some brake cleaner and not start or rev, its timing, if it starts easily and doesnt give you too much trouble its a/f which could have been easily ruined when changing the exhaust side of the system and messing with jets.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I dont care if you never even ran it, replace the intake gaskets. The problems your having are EXACTLY like the ones I had that were corrected with new gaskets.
Bluethunder3320
oh... i thought removing the rod and crank was the only way.
anyways i got the governor back in, and now i have to put everything back together. tomorrow tho its time for bed.
devino- ill try making a gasket from a thin cardboard box... bcause i cant wait for shipping right now.... lol.
if it still has this problem ill order a gasket... well maybe ill order one tomorrow since they are cheap.
devino246
Lynchburg, VA
Just go to autozone, advance, O'Riley's, Napa or whatever autoparts place is close and get some gasket sheets.
Wim
Jazz Maverick
Oz
One more thing, that little kill switch you've got. Move it. If everything comes to a stop very suddenly it's going to rip you nuts out.
Just saying. :roflol:
Thanks
Hayden
Wot he said, seriously do it! Unless you want to see what your gametes look like in their natural habitat.
Gaskets: I assume you ran it and sprayed some WD40 (or similar) around the gasket (not carb intake) to see if the revs change? If they do you've got an air leak.
devino246
Lynchburg, VA
:roflol:I didnt even notice that! Ouch:ack2:
Bluethunder3320
SCORE!! the guy at HF never thought to even open up the box... he said whatever comes in a new one goes out... no questions at all.
HF rocks!!!!
plus, he refreshed my warranty so i have another 2 years AND 90 days.
