pit bike engine
coolkarter
steinbach, manitoba
hey i was thinking of putting a pitbike engine in my kart (pitster 125) im getting the whole bike so im also going 2 use the brakes etc but im wondering of how i can prepare it :)
Bluethunder3320
take the old motor out... maybe start working on a shifter lever. and clutch pedal (assuming its manual)
then once you get the caliper and everyhting else you can make brackets or cut them off the bike and drill motor mounts.
also need to figure out how ur gonna mount the tank.
coolkarter
steinbach, manitoba
im going to strengthn the frame first to handel the extra power of the pit bike motor and with the shifter would i push it up to shift up and push down to shift down
redsox985
PA
What kind of frame do you have? If it's small, you could sit next to it, rotate the shifter arm up, and fab a longer arm. I bought a motor like this from a kart, the seat was to the right (when looking at the front) and the motor on the left. The shifter arm was extended upward with 1" OD pipe and the bike's twist throttle was on the shifter arm. So drive with your left hand, throttle and shift with your right, clutch with your left foot and brake with your right. Interesting, but practical.
Rustydog2010
NZ Nutta :|
New Zealand
So you only had one hand on the steering wheel? Dosent sound to practical to me...
Jeremy.
redsox985
PA
You don't understand the guy I bought it from, it was a rough part of town, he was looking BA and revving it high in neutral. As long as full lock is less than about half a turn, it should be do-able.
coolkarter
steinbach, manitoba
no my frame is designed for have a mid/rear engine and its a 125cc 4 stroke with a 4 speed manual with manual clutch it can get up to 60mph its from a pitster pro i might try what redsox985 suggested would that work with a mid engine?
redsox985
PA
Could you make a suicide shifter with a hand clutch? So that you gas with a foot pedal then let off and clutch and shift with some type of linkage? Like this (but moved up by the driver, not back on the motor):
Bluethunder3320
i would make 3 pedals, (clutch, gas, brake) and a lever that is just a solid bar you push up and down.
