TC2 Torque Converter
weekendwelder
New Member
Last Night I Ordered a TC2 Torque Converter from GoKartsUsa, and I just thought that I would start this thread because there aren't many reviews about. So when it comes in the mail, I will takes some pictures and maybe even a video about it, and give you my opinion whether or not it is worth buying. Until then, feel free to post anything you know about it, good or bad.
metalthrashinman
Hope, NJ
It depends what application you are using it for. If your gearing is not right and your engine is over 8hp, get ready for some frustrating belt burning nightmares. :worried2:
weekendwelder
New Member
Right now I've got a stock 6.5 HF Clone engine on a manco intruder. After tearin up two centrifugal clutches, I realized that I needed a tc.
weekendwelder
New Member
I got 12" tires on the front, and 18" tires on the back. I a live axle with a 60 tooth #41 pitch sprocket. It is the same go kart as my profile picture, except it now has new tires, shocks, brakes, and I am rebuilding the seat today.
Camdat67
Riverland. South Australia
Fairly happy with TC2
I got mine 2 sent to Australia from gokartsusa 2 months ago. I am pretty happy with the final result, but like metalthrashman said there are a few minor issues.
1. On a 13hp honda clone the CVT has to go driven pully to the front because it hits the cooling fins the other way around.
2. On a 13hp clone you have to machine the spacer to align the 2 pulleys.
3. The nylok nut on the jackshaft only just goes on far enough to lock onto the nylon.
4. If you overtighten the nylok nut just a little bit too much the circlip on the other end comes off, but this is an easy fix-Just get a hacksaw and carefully deepen the circlip groove (just a little bit). This gives the circlip a deeper grip.
5. Dont believe that a GTC TC2 will handle 13hp. As I learned on this forum, when Comet made them they were rated to 8hp.
Most of the problems with my unit are caused by using a 13hp motor and not the fault of the unit itself. As I have said before I am running it on a heavy dirt buggy with 22" rears a 10tooth/60 tooth sprocket combo, but I have ordered an 80 tooth rear sprocket, but if it keeps cooking belts, I,ll bite the bullet and get an 8hp motor instead. If GTC want to sell a CVT for 8hp and up they should start also making the next one up from the Comet TAV2.
In summary the GTC unit is well made and very reliable. I would recommend anyone to get one as it makes the buggy so much fun to drive.
Cheers.
Simon.
metalthrashinman
Hope, NJ
CAMDAT67, IMO; don't get a lower hp engine, keep experimenting with your gear ratio to give you maximum torque while still keeping the TC happy enough to not burn belts and shift properly. It is very do-able. You are on the right track with the larger rear sprocket, but don't give up on finding an 8t front. It IS available, and will compliment your 80t rear very well.
weekendwelder
New Member
I added some more pictures of the tc fully assembled at some close ups of the jackshaft and the final drive, and I added a few pictures of the seat that I built entirely from scratch last weekend. Btw, let me know what you think of my seat and my site, I'm fairly new to making a website and such, its just what I do when I run out of money to build things.
http://brandonsgarage.weebly.com/pictures.html
metalthrashinman
Hope, NJ
Nice site, nice seat! Hey, looks like we have the same kart; but you painted yours black.
weekendwelder
New Member
Yeah, I think it was originally red, then the guy I bought it from, had painted it blue, and then I painted it black. Thanks for the feedback!
