wont start
Eric492
I have a x2 pocket bike with a 49cc two-stroke and the thing wont start!:censored:
I think it's the carb so I took it off cleaned it up and rebuilt it, and its getting a new spark plug and fresh gas...
other then that its getting the wiring redone but anything else i should check?
r97
Measure twice cut once
Massachusetts, USA
is it getting a spark? get some carb-cleaner and take off the air filter and spray the carb cleaner right in there, then try to start it, if it starts momentarily, its your carb.
Eric492
tried it and no it didnt start period thats why the sparkplug is getting replace
Bluethunder3320
wow, i have almost that exact same motor. i get all my parts from scooterparts4less.com. mine didn't start and i had bad compression, but check if its firing by pouring a little gas into the intake port, then crank.
